Tire rotating wrong direction
Old Oct 23, 2008 | 07:32 AM
Viejo's Avatar
Viejo
Default Tire rotating wrong direction
When dealer replaced my front tire and wheel they mounted the tire rotating against the arrow. I am going to remove the wheel and turn it around. But my question is should I also take off the rotors to keep them on the same side going the same direction or will they conform to the pads on the other side? 16000 miles on front brake and they are still fine. 6000 miles since the tire was installed wrong,
Sorry for the long question and I really appreciate any advice you might have for me.
Old Oct 23, 2008 | 07:35 AM
Hog Yild's Avatar
Hog Yild
Take it back to the dealer, they need to know they screwed up and they need to fix it the right way.
I just went through a starter problem that they should have been aware of but they were not. They said it wasn't under warranty, until I brought them the official HD Service Bulletin that I downloaded from this forum and gave to them.
Keep them honest. You paid for service, expect service. 6000 miles or not.
Old Oct 23, 2008 | 07:57 AM
IndyRider's Avatar
IndyRider
If you just flip the whole wheel then it will be wrong also. The tire needs to come off and re-installed the correct way. I would take it back to the dealer and have them do it.
Old Oct 23, 2008 | 07:58 AM
Orion1369's Avatar
Orion1369
Back to the dealer, they screwed it up they should fix it.
Old Oct 23, 2008 | 08:06 AM
Hog Yild's Avatar
Hog Yild
Check with the tire manufacture and see if there were any ill affects with running the tire backwards. Reduced mileage, or if there is a problem in turning a tire around that has been driven 6000 backwards etc.
If there is damage caused by running a tire backwards, demand a replacement. Their screw up not your's.
Old Oct 23, 2008 | 08:21 AM
huffhuff's Avatar
huffhuff
running a tire backwards may not disperse water correctly in wet conditions and can cause hydroplaning. on dry pavement it may not be a safety factor.
Old Oct 23, 2008 | 08:26 AM
Bertk's Avatar
Bertk
Agreed! Bring it back to the dealer and have them make it right. They don't put those arrows on there for nothing. Then find another place to have your bike serviced.
Old Oct 23, 2008 | 08:42 AM
Sheep's Avatar
Sheep
I'm searching for that bulletin with no luck. Care to point me towards it?
Old Oct 23, 2008 | 08:43 AM
Chicago Spike's Avatar
Chicago Spike
bike tires are almost always made to push water AWAY from the center of the tire. If it is run backwards, it will push water INTO the center of the tire causing hydroplaning very easily.
Wheels are also made to run a single way, so flipping the wheel around will cause other problems.
As said, TAKE IT BACK TO THE DEALER THAT SCREWWED UP!! Demand they fix it right away while you wait and watch them.
Old Oct 23, 2008 | 08:56 AM
skooba's Avatar
skooba
Next time:
Check the arrows before you leave the dealership. It's your a** not theirs.
This Time:
6000 miles - I won't change the direction on that tire, it maybe mounted wrong but its now run 6k in the wrong direction. If there has been any damage to the body of the tire, changing direction is not going to make it any safer to run. May even be worse at this point.
Point out the mistake, explain that you just noticed it and make a pro rated deal for a new tire with free mounting/balancing.
It's an honest mistake, I've done s*** a hundred times at work and always at least once managed to do it wrong. I know that's what they get paid for, but honestly who is really 100% perfect. And this is not something you would intenionally do to get a deal on a tire.
If you plan on continued service from that dealer it's best not make enemies out of them. It's better to be know as Mister than A**hole.
