Warranty
Old Oct 23, 2008 | 03:44 PM
scasey's Avatar
scasey
Default Warranty
I am thinking about purchasing an 09 street glide and this is my first Harley. If I put the wheels 21 inch wheels and other little tid bits does that void any warranty? Does it have to be done by the dealer cause I would hate to pay their rates.
Thanks
Just looking for info new to this
Old Oct 23, 2008 | 04:21 PM
extech's Avatar
extech
well, obviously, they won't warranty the wheels or anything associated with them.
Old Oct 23, 2008 | 04:22 PM
captjon37's Avatar
captjon37
You need to ask the dealer that as they will be the 1 to honor it.
Old Oct 23, 2008 | 05:26 PM
EZ48's Avatar
EZ48
Adding aftermarket parts and doing the work yourself will not void the warranty in total but it may give the dealer the ability to deny a claim if it can be proven that the accessory or work performed did in fact cause a problem you are wanting them to cover.
An example would be you added aftermarket cams and shortly afterwards your top end frags itself. Probably not a good case to get HD to cover the repair.
Old Oct 24, 2008 | 05:58 AM
scasey's Avatar
scasey
What about aftermarket pipes? Does that void engine warranty?
Old Oct 24, 2008 | 09:26 AM
Harleypingman's Avatar
Harleypingman
Ordinarily, no, aftermarket pipes don't void the factory warranty. When you change pipes and air intake, you will need to have the ECM (the bike's brain that controls fuel and ignition timing) recalibrated. If you don't recalibrate to richen the fuel mixture, there's a good chance the increased air moving through the engine will lean the fuel mixture to the point where you have engine damage which would not be covered by HD.
If you buy the SG, do yourself a big favor and buy the HD Service Manual, Electrical Diagnostic Manual, and Parts book for your bike. Ask to look at them at the dealership and you will get a good idea of how valuable they are.
Tooth
Feb 6, 2013 04:08 PM
Joe13SG
Oct 6, 2012 08:29 PM
DaveMK
Apr 23, 2008 09:02 PM
HarlyFan
Sep 7, 2007 07:50 PM
heavy hauler
Apr 15, 2006 02:52 PM
