Road Glide Front End
Old Oct 26, 2008 | 04:25 PM
HOGWYLDPR's Avatar
HOGWYLDPR
Default Road Glide Front End
I am planning to install chrome front forks and lowering kit on my 08 Road Glide. I want to do this install myself and save a few bucks. Has anyone done this job? I know it involves removing the inner fairing, not sure if I have to do the outer as well. I have a tech manual and I have done this on my softail but I could use some helpful tips or tricks from those who have done it before. This install on the Road Glide looks like it will be a big PIA. Anyone?
Old Oct 26, 2008 | 07:05 PM
meveratt's Avatar
meveratt
The outer fairing is just 6 Torx screws, and the turn signal bolts. Pretty easy and quick. From there I'd see what kind of access you have to the fork clamps. I can't remember whether I could see the clamp bolts or not when I had the outer fairing off to install my Hogtunes speakers.
Old Oct 26, 2008 | 07:13 PM
BadPiggy's Avatar
BadPiggy
I'm trying to remember...
But I don't think the outter/inner fairing has to be removed from a RG to do fork work.
The tubes are located in the speedo housing (switch cap) and I believe that's accessible without removing the fairing.
Been several months since I've done a RG...but from what I remember, didn't have to remove these items.
Old Oct 27, 2008 | 04:50 AM
HOGWYLDPR's Avatar
HOGWYLDPR
Thanks for the response guys, I'm going to do this thing. The only tricky part I can see would be removing the ignition switch. Anythinbg to look out for there?
Old Oct 27, 2008 | 07:55 AM
steveh326's Avatar
steveh326
sorry I can't help, but here's a bump for you and I'll be following this thread... took me a year but I have finally accumulated the parts to do mine and will be tearing into my RG sometime after the weather turns colder.
otto76689
Apr 29, 2016 08:24 AM
stevec
Aug 24, 2011 03:22 PM
Puttnutt24
Aug 8, 2009 06:58 PM
garyhendley
Jun 13, 2009 09:38 AM
TampaJim
Feb 20, 2007 09:54 PM
