12v Heated Jackets
warmgear brand
http://cozywinters.com/heated-clothing/
For Tourmaster heated gear
http://www.compacc.com/cat.cfm/cid/1001005
Warm n safe heated geat
http://www.warmnsafe.com/
Gerbings at 20% off
http://www.grandprixmotorsports.com/default.asp
Gerbings return/blem/outlet
http://heatedclothingoutlet.com/index.shtml
if wearing HD branded clothes is your number one concern then go with the HD
I'd suggest get the double thermostat - has two seperate plugs so you and hubby can pick diff heat levels
I had called Gerbings and got nowhere, the girl on the other end of the phone thought I had a degree in stupidity. All I wanted was a wiring diagram for the jacket.
My jacket had five leads, three by the left hip and one at the end of each sleeve.
Here is what I found out with my ohm meter. The connector that is labeled gloves, insert it into the battery harness. This will provide power to the connectors at the end of your sleeves and to the accessory plug. Second, insert the jacket connector not labeled into the accessories connector, this will provide power to the jacket.
This is a simple solution to when Gerbings says that you need to buy a splitter to use both the jacket and gloves at the same time.
PS... I love riding in the cooler weather of Nebraska now, I still need a good Balaclava though.
