Adding air and checking tire pressure
Old Oct 31, 2008 | 12:46 PM
Pope's Avatar
Pope
Default Adding air and checking tire pressure
I know I should search the forum, but I don't feel like weeding today. Is there a trick or special tool you can attach to a standard air compressor...the type we find out on the road like gas stations? I can't get a pressure gauge on it because of the spokes and rotors, and I play hell trying to get an air chuck on the stem. I spent all my quarters trying. These wheels and rotors are OEM on an Ultra.
Old Oct 31, 2008 | 12:52 PM
captjon37's Avatar
captjon37
I just use a gauge with a rubber hose and 90* chuck head similar to the HD model. It holds pressure reading. You can get a 90* valve stem to use at gas stations. I keep 1 in my tool bag for just that.
http://www.getagauge.com/DialTireGauges.cfm
Old Oct 31, 2008 | 01:22 PM
Geoff's Avatar
Geoff
I have a gauge that's attached to the chuck on my compressor hose, but I prefer this type. It's more accurate and I can carry it on trips.
Old Oct 31, 2008 | 01:27 PM
dkatko's Avatar
dkatko
2nd Gear
I have a gauge that has a hose coming out of each side. One attaches to the tire valve and the other to the air source. You can read the gauge while filling without having to disconnect either side. I had looked around for sometime and finally found it at Advanced Auto.
Old Nov 4, 2008 | 07:32 PM
Volfan615's Avatar
Volfan615
I was just going to post a similar question but decided I'd try to quick search and found this.
I have a compressor at home but it took me about 30 min to check tire pressures the other night with these spoke wheels. I was literally cussing the whole time. The back is works than the front. It would be much easier if the valve stems were at an angle.
Any advice would be very much appreciated.
Old Nov 4, 2008 | 08:06 PM
capt_caveman's Avatar
capt_caveman
Are the rims different on the 09's? I don't have any problems with my 05's spoked wheels.
Old Nov 5, 2008 | 01:15 PM
bigskyhd's Avatar
bigskyhd
The 90 degree valve stems are really the answer. They make it much easier.
Old Nov 5, 2008 | 02:12 PM
hawg08's Avatar
hawg08
How about a 90 degree chuck on the air gauge?
Old Nov 5, 2008 | 02:14 PM
hawg08's Avatar
hawg08
Where did you get the 90 degree valve stem that you carry in your bag? I ordered the 90 degree gauge with hose. Looked pretty good.
rollingthunder
Jul 19, 2014 07:48 PM
Redlegvzv
Jun 8, 2014 07:09 PM
GodFather
Jun 21, 2009 07:32 PM
Rollon
Jun 11, 2009 01:15 AM
Topspin
Oct 14, 2007 10:30 PM
