I'm in for one as well. I have a question about shipping. Any issues shipping to Canada?
No problem with shipments to Canada, we just need your full address. We will pay $10 towards the charges as we average this amount for state side orders. Zeus we sent a PM to you also.
Guys the link to the page is http://www.wheeldock.com/H-D_forum_member.shtml and if you want to be counted as an order you need to read the offer and send us an email or give us a phone call so we can get your information. This is the only way it counts. I will pay for the call too. 1-866-606-3080
Just sent an email with the info. COUNT ME IN!!!!!!!!
As long as someone can confirm that I can still use my yellow Harbor freight aluminum bike lift I'm in too.
Good Question,
You did not say which year model you have so since this might be helpful information I will cover both the old stand and the new version for the 09 bikes.
As we have only gotten about 150 of the new 09 stands out so far I can't give you first hand information on you being able to use your jack with this new model. We did get feedback from a customer either on this forum or the V-Twin who said all he had to do was add a small piece of plywood to one side of the frame to level everything out. I assume the rear arm of the jack was setting on the mounting bolt which would give about 3/8th inch gap under the other frame rail. He might have been able to just position the arms an inch forward and been good to go without the spacer. Dont know.
On the pre-09 model we have never had a customer who could not use his lift in conjunction with our center stand. Another point I would like to make: when a bike is first setting on a center stand you can usually slide the jack all the way under both frame rails. This is because not only is the bike level but setting taller than on a side stand or pulled back to a vertical position by hand. If you use a ˝ inch piece of plywood under my center stand then put the bike up it is even taller and the rear tire is off the ground for cleaning. You might find less need of the jack. Hope this information helps.
I called to order also an they were closed, I will call back in the morning and order, so you can count mine also.
We will be out tomorrow and back in the office on Friday. But you and 09RoadGlide are counted and are numbers 7 and 8. If you will email sales@wheeldock.com with your information we will add you to our rapidly growing list of sales. Wow guys what a great response to our deal! We just posted this offer this afternoon.
Next week I will be out of the office on a deer hunt in Kansas and will have no internet and probably no cell service so Susan Muench, my office manager will be fielding your calls. If you have technical questions I will get with you when I am back in the office the following week of Dec. the 8th. It sounds like I have a lot of you guys who have my center stand already so they should be able to add a bit of tech support also.
Thanks guys,
