Wheeldock Easy up center stand
Old Nov 26, 2008 | 07:32 PM
  #51
Raaze07's Avatar
Raaze07
Originally Posted by vrodb
Good Question,
You did not say which year model you have so since this might be helpful information I will cover both the old stand and the new version for the 09 bikes.
As we have only gotten about 150 of the new 09 stands out so far I can't give you first hand information on you being able to use your jack with this new model. We did get feedback from a customer either on this forum or the V-Twin who said all he had to do was add a small piece of plywood to one side of the frame to level everything out. I assume the rear arm of the jack was setting on the mounting bolt which would give about 3/8th inch gap under the other frame rail. He might have been able to just position the arms an inch forward and been good to go without the spacer. Don’t know.
On the pre-09 model we have never had a customer who could not use his lift in conjunction with our center stand. Another point I would like to make: when a bike is first setting on a center stand you can usually slide the jack all the way under both frame rails. This is because not only is the bike level but setting taller than on a side stand or pulled back to a vertical position by hand. If you use a ˝ inch piece of plywood under my center stand then put the bike up it is even taller and the rear tire is off the ground for cleaning. You might find less need of the jack. Hope this information helps.
I have an '09 Ultra.
Old Nov 26, 2008 | 07:33 PM
  #52
brihvac's Avatar
brihvac
I will be calling Friday morning for sure
Old Nov 26, 2008 | 08:24 PM
  #53
r8rs4lf's Avatar
r8rs4lf
By the looks of it, we should have no problem making the 15 orders for the 20% off.
Another question which has already been asked...........
Are you going to stop at the 15 orders for the 20% off and if the order goes higher, will there be even more savings? Not that I'm complaining though.
Old Nov 26, 2008 | 08:29 PM
  #54
brihvac's Avatar
brihvac
He hit the jackpot coming on this site. Im up for saving some more money. Economy is bad
Old Nov 26, 2008 | 08:31 PM
  #55
brihvac's Avatar
brihvac
Man, I dont really like denim bikes but your EG is kick a$$
Old Nov 26, 2008 | 08:45 PM
  #56
RODEO's Avatar
RODEO
I'm in too! Sounds like a well made product and a solid vendor.
I'll make the call on Friday..
Old Nov 27, 2008 | 07:09 AM
  #57
Deepsouth251's Avatar
Deepsouth251
Just wanted to bump this to the front so others see it!
Old Nov 27, 2008 | 07:26 AM
  #58
prestaino's Avatar
prestaino
I'm in I will call tomorrow.....
Old Nov 27, 2008 | 07:49 AM
  #59
Twinrider's Avatar
Twinrider
Talking
Mine's coming tomorrow, will post up pics
Old Nov 27, 2008 | 08:18 AM
  #60
HDV-GLIDE's Avatar
HDV-GLIDE
For the guys who have one already, does it decrease the bikes ground clearance at all???
