HD Garage Door Opener Issue
Old Nov 3, 2008 | 03:48 PM
RoadKing_Al's Avatar
RoadKing_Al
HDUltraRider is the ballast for the HID grounded to the frame? If not try it.
Old Nov 3, 2008 | 04:23 PM
vzts4q's Avatar
vzts4q
Default HD door opener
[QUOTE=Thirdup;4068961]Out of curiosity, what's involved in the installation of the HD opener (transmitter) to the bike? Is it plug/play or do you have to disassemble/solder anything? I tried to google the instructions, but no luck.
4 wire total The follow instructions are for a Ultra but the sources are the same you just pick them up in other palce on not touting bikes.
1 to + 12 volts (unused wire in headlight harness)
1 to ground (unused wire in headlight harness)
1 to high beam wire
1 to low beam wire
All the connectors and good instructions come with the transmitter.
Old Nov 3, 2008 | 04:55 PM
kpb46's Avatar
kpb46
Originally Posted by HDUltraRider
Ok, I know there have been a lot of post on this one however I have a question, already made the investment and installed on my bike. However I have recently upgrade to a hid headlight and with the Balist and starter inline it no longer works off of the bright switch.
Wondering if anyone has any experiance with this and has come up with an alertative hook up for the HD devices to get around this issue?
Give these guys a call. Ask them. They are great to work with. But you may want to tell them you have one of their units. Theirs work the same as a HD
http://www.electricalconnection.com/
Old Nov 3, 2008 | 06:07 PM
Chicago Spike's Avatar
Chicago Spike
Tin foil huh?? Doesn;t the balast now get too hot?
mikebaby
May 20, 2021 06:49 PM
SSK
Mar 28, 2016 11:35 AM
zion
The General Motorcycle Forum
Jun 19, 2014 12:25 PM
2007harleyman
General Topics/Tech Tips
May 10, 2012 04:37 AM
Kevinm40
May 2, 2011 02:08 PM
