Free Fix for Touring Wobble
Old Nov 2, 2013 | 01:43 PM
  #121
fmlstewart's Avatar
fmlstewart
5th Gear
After further inspection, I found the front motor mount center bolt was missing the nut. The bolt was just bouncing around in the mount. I put a nut and lock washer on it, and replaced the stabilizer bolt. There was zero psi in the shocks. I set them at 18 psi and put 37 psi in the rear, 35 in the front. Wobble seems to be gone. No high speed shimmy. Should've done a better inspection before the first ride...
Old Nov 2, 2013 | 02:15 PM
  #122
Jumpman's Avatar
Jumpman
Glad to hear it.
Is give it a few hundred miles to see how it rides before you put $'s into the stabilizer.
Old Nov 3, 2013 | 10:02 AM
  #123
fmlstewart's Avatar
fmlstewart
5th Gear
The stabilizer may not be an issue now. Out of curiousity, has anybody played with the fork oil level to soften or stiffen the front end up a bit?
Old Nov 3, 2013 | 11:03 AM
  #124
toothmansteveb's Avatar
toothmansteveb
Just a note about the True Track. I have been disappointed with any performance improvements and the design dose not allow you to fit a socket on the tranny drain bolt. The guys at TT said to use a thin wall wrench to loosen the bolt that is now between the TT and crossmember. Then remove with hex head. They could have made the access hole just a little larger. Don't waste your $.
Old Nov 3, 2013 | 11:20 AM
  #125
BLKPRLFLHTCU's Avatar
BLKPRLFLHTCU
Even if there was no alleged wobble someone would come up with something else to complain about. I would think that the aftermarket companies would come up with some other product that "you must have". Every car and truck has it short comings nothing is perfect but I still think my Ultra is as good as it gets... I still can't figure out why anyone needs to do 100mph on a glide. Its like running a Winnebago on a nascar track.
Old Nov 3, 2013 | 03:24 PM
  #126
grbrown's Avatar
grbrown
Lightbulb
That's condemning something that works and benefits you every time you ride, for a couple of minutes inconvenience every few thousand miles!
Old Nov 3, 2013 | 08:06 PM
  #127
chaswood's Avatar
chaswood
FYI 2008 was the last year that you align your rear wheel. In 2009 the changed the motor mounts at the top of the engine. I have a TRW stabilizer and it works great! I also aligned my rear wheel, It rides like its on rails. I also ride fast, but the bikes are not designed to drive at 105 mph.
Old Nov 3, 2013 | 08:39 PM
  #128
6 gun's Avatar
6 gun
It don't make a hill of beans to me how old a thread is,
if someone needs some help, well here we are. Like others
have said Welcome here is a few things to see.
(1) http://www.throttleupindustries.com/...tabilizer.html
(2) https://www.google.com/search?q=Thro...l=np&source=hp
I hope this helps you out I got the throttle up touring stabilizer
and I love mine.
Old Nov 3, 2013 | 08:56 PM
  #129
Clint55's Avatar
Clint55
Hey... thanks for the memories. Tomorrow will be exactly 5 years since I started this thread..
In case anyone's interested, I never bought a stabilizer for the 08. Now rid'n an 09. Neither of these bikes ever killed me yet.....but they've both tried!
Old Nov 3, 2013 | 09:25 PM
  #130
6 gun's Avatar
6 gun
Hey Clint 55 You are welcome for the memories lol
I had to have a stabilizer cause I know for a fact this
will be my last bike and I hated the wobble. I remember
when Aaron got the price down low enough, for long
enough my "pucker problems" would be over and I was
right. Thank you for the memories as well.
