Free Fix for Touring Wobble
Old Jul 1, 2014 | 01:41 PM
  #141
mgmmgm's Avatar
mgmmgm
I have felt the wobble on a 70 mph on a freeway sweeper- I did not come into the the sweeper HOT, this was about 4 months after getting my NEW RKC. Tire pressure spot on to factory sticker on frame, tires less than 6,000 miles on them, and I weigh 160 lbs., the bike was not in any way overloaded. I was solo and not carrying that much for a week long ride trip to California.
Let me tell ya.... when that f-tard bike started wagging on me-
It was not a fun experience but I knew what it was, as I had read about it here.
I got the b-hutch under control, but the experience pissed me off, as you don't expect stuff like that to happen. My first HD was a 07 FLSTF which I traded in for the FLHRKC. I also had in my past street ride experience a 750 Yam, and a 650 Yam, and I grew up riding dirt bikes.
I have considered a bagger brace such as the true trac and will probably get one. I just remain cognizant of the fact that the potential for wobble is there. I check my tires weekly and keep my speed lower than posted going onto those sweeper corners.
Old Jul 1, 2014 | 02:15 PM
  #142
KCFLHRC's Avatar
KCFLHRC
Never experienced this on 3 Harley touring bikes, 1 2010 and 2 2011's. Probably why Harley doesn't admit a problem, it's just not that widespread. But if and when it does happen to me, I will look at changing brands.
Old Jul 1, 2014 | 02:46 PM
  #143
skypilot_one's Avatar
skypilot_one
This is more a problem with the older pre 2009 frame. HD has slowly made improvements, new swing arm, swing arm bushings, and larger transmission bolt in 2002, new frame design in 2009, now in 2014 a new frame neck design with larger bearings and bolt, larger fork tubes and stronger triple trees.
I have experienced the "wobble" changing lines in a curve and hitting a seam in the road. NOT fun. Tire pressure, fork and shock pressure good, bike aligned, head torqued to spec, one up, not over the gvw. This is with the bagger brace. Had it happen every time a mile from my house at 30 mph in a left hand sweeping turn that has a bump in it. That's more of a wallow.
The original design works for an FXR weight bike, not for a dresser. The FXD has had a larger front end than the touring line for how long?
Old Jul 2, 2014 | 11:33 AM
  #144
Max Headflow's Avatar
Max Headflow
The thicker swingarm doesn't do as much as the tire profile change and the added trail in the front.. They even sorta screwed up where the issue is.. The rear drive train mount.. On the newer frames, they use a die stamped 1/2 round piece to hold the rear drive train mounts and bolt the tail section on.. Is that stronger than the 08-ealier frames with full round tubing and a boxed section .. Doubt it.. I need to get my hands on a later frame too check..
Old Jul 7, 2014 | 06:05 PM
  #145
JMB19's Avatar
JMB19
4th Gear
I am a new Harley rider but, not new to motorcycles and experienced this on 7/6/14 on I-75S near Bay City, Michigan. 1994 Ultra, New tires, no load, Cruise locked on 70, 1 up and, the back of the bike in a long sweeping turn felt like it was all over the road. I don't recall any dip, hump or, tar snake. My son following behind in my truck said he SAW the bike all over the place. He asked what happened before I mentioned it. Found this thread looking for a fix. Why is it that some of these braces say 95 and up and some say they are for 80 and up? Definitely needs something.
Old Jul 8, 2014 | 03:05 AM
  #146
grbrown's Avatar
grbrown
Wink
They use the transmission casing as an anchor point for the rear stabilizer and the design of that was changed for the 1995 models, simple as that.
Hi from the UK and welcome to HDF. If you haven't done so yet read my thread on bagger wobble, so you get up to speed on the subject. There is no obligation to read beyond the first post!
Old Jul 9, 2014 | 07:59 PM
  #147
Yachtman's Avatar
Yachtman
I'm curious as to what a '70 freeway sweeper' is, and what 'coming into it hot' means. Is it an off ramp, which can sometimes be taken too hot? I don't think I've ever seen an off ramp with a posted speed limit, only 'suggested' speed limit. I've never had a sweeper on a highway sneak up on me! Usually I can see them coming from a distance, or I'll have seen the big sign that let's me know what's ahead. I have had a few lighter wobbles on my 2001, but never serious enough to complain, and I always knew what I did wrong. Lesson learned.
I don't mean to be picking on anyone, please believe that. I'm just using this as an example of 'possibly' going to fast to begin with. Are wobbles a fact, absolutely. A design issue, probably. Avoidable? Well,..........😳
Old Jul 9, 2014 | 08:14 PM
  #148
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
I don't mean to be picking on anyone, please believe that. I'm just using this as an example of 'possibly' going to fast to begin with. Are wobbles a fact, absolutely. A design issue, probably. Avoidable? Well,..........?de33
Maybe the rest of us just aren't skilled riders like yourself.
Old Jul 9, 2014 | 08:56 PM
  #149
Yachtman's Avatar
Yachtman
Cool
There was nothing in my post where I said I was any more skilled than anyone else. I will brag about my skills in avoidance, though, if that makes you happy.
On I95 here in S. Fl it's dangerous enough to just ride in your car. South of Palm Beach and it's even worse because the Gray Hairs are in larger numbers. In my car I'll go 85, maybe 90 in a 70 zone. Slower speed limit and I slow down. But on my Road King I'm at the speed limit and no more (mostly, I do pass when needed!)
So what do you take away from the example I've just written. That I'm aware of my surroundings. Not bragging about any other skills than my own common sense.
How's this: if you can't see a freekin 70 mph sweeper coming at you, then you shouldn't be driving anything. Period. If you don't slow down for an on or off ramp to a speed appropriate for you and your ride, car or bike, then I can't help you. And I drive high performance autos, so I'm no saint, believe me!
And again, wobbles can happen even in a straight line sometimes. They start somewhere!?
Old Jul 9, 2014 | 09:03 PM
  #150
jammerx's Avatar
jammerx
Originally Posted by Uncle Paul
Never saw any forum posts about high speed wobble on bikes that were doing the posted speed limit on sweeping turns. It was always from people exceeding those limits.
Maybe that is why HD never publically responded.
On my 07 I only experienced high speed wobble when going significantly over the posted limits on highway sweepers. Slowing down just a bit always made the wobble go away.
Maybe these are 800 lbs. cruisers, not racers.
No wobble at all with my 12.
HERE HEAR No wobble on my 12 either...
