Walmart Driving Lights
Old Nov 6, 2008 | 12:50 PM
Bluesssman's Avatar
Bluesssman
Very nice. I like finding solutions for bikes that cost much less than what Harley wants to charge!!
Old Nov 6, 2008 | 01:29 PM
TheShrink's Avatar
TheShrink
For the switch, I tapped into the wire that is next to the headlight under the fairing. It was the one with the red cap. The switch doesn't pull much power at all. I then ran the wires under the tank with the main harness to where the relay is under the seat. The relay is wired to the battery. The wire for each light was routed through the lowers, (where the inner & outer wrap around the engine guards), and then up the front of the frame to the main harness, then under the tank to the relay. Hopefully this made sense. None of the wires can be seen and the only hole that I drilled were for the switch.
All I can say is they are pretty damn bright and well worth the $15 and they fit with the lowers on, unlike the HD ones. I had all of the lights on for the picture, but at night I do turn the spots off and run the headlight and these lower lights. It looks like an airplane coming at it looks like broad daylight from the drivers seat. Also, I would watch the drivers that were coming at me, and as they went by, and not one of them had light in their eyes. None of them flashed their lights at me either. Guess I got them aimed right.
Old Nov 6, 2008 | 01:44 PM
Primo's Avatar
Primo
Very nice. Good job thinking outside of the box.
Primo
Old Nov 6, 2008 | 01:50 PM
iclick's Avatar
iclick
Do these use H3 bulbs? What is the wattage?
Old Nov 6, 2008 | 02:53 PM
TheShrink's Avatar
TheShrink
They are 50 watts each and have the Halogen bulb with reflector on it. Alot of White light!
Old Nov 6, 2008 | 04:54 PM
Cache's Avatar
Cache
Nice set up!.....What goes on the X-mas tree?
Old Nov 6, 2008 | 06:59 PM
KBrown53's Avatar
KBrown53
good job!
do you have the part number for the light mounting bracket?
Old Nov 6, 2008 | 07:05 PM
StreetGlide53's Avatar
StreetGlide53
No Chrome Regulator Cover???????
Old Nov 6, 2008 | 07:06 PM
will2002's Avatar
will2002
Neat setup all the way around. Really looks good!
Old Nov 6, 2008 | 07:08 PM
Chula's Avatar
Chula
I like them.
