Walmart Driving Lights
Old Nov 7, 2008 | 10:41 AM
  #31
clap's Avatar
clap
Thanks Shrink , I can't even see the screws in your pic's that hold the switches in.
Old Nov 7, 2008 | 10:51 AM
  #32
TheShrink's Avatar
TheShrink
I drilled 2 - 3/8" holes for the switches. They have a threaded center that take a "nut" on the inside of the fairing. There is nothing to see on the dash other than the switch itself.
This project took more time than money, but I done a good job, so I'm gonna pat myself on the back. Now, for the other 1000 times I screwed something up - we won't talk about that.
Thanks for all of the positive comments, I appreciate it.
Old Nov 7, 2008 | 12:01 PM
  #33
MNPGRider's Avatar
MNPGRider
Thanks for the info, shrink. Winter hit this morning, so now I've got lots of time to kill in the garage....
Old Nov 7, 2008 | 04:19 PM
  #34
Bertk's Avatar
Bertk
Thanks for the added info Shrink, I'm going to get a set.
Old Nov 7, 2008 | 04:28 PM
  #35
Jrsess's Avatar
Jrsess
If it works ? Why not!
Old Nov 7, 2008 | 05:25 PM
  #36
MNPGRider's Avatar
MNPGRider
I have a set of Saeng NiteCutters retangular lights that I had mounted down low on my last road bike, an '84 Venture. I found them invaluable for driving in the rain, as they had a patented swivel mount and were instantly adjustable. Caught in the rain, I could point the right one down to the white line on the edge of the road. They have since changed their design to a round light, but their price is in the hundreds of dollars.....In fact,they charge more for the bulbs than you paid for the lights !
http://www.saeng.com/cutters.htm
Old Nov 7, 2008 | 07:08 PM
  #37
bsea's Avatar
bsea
I LIKE it! This goes onto my winter mod list. Correct me if I'm wrong, but looks like this setup does not interfere with the lowers, right? Thanks for an excellent idea.
Bill
Old Nov 7, 2008 | 08:43 PM
  #38
Bushy's Avatar
Bushy
nice alternative to HD's fogs, not that they work on on Ultra lowers, thanks for they pics and wisdom
Old Nov 7, 2008 | 09:28 PM
  #39
TheShrink's Avatar
TheShrink
You guys are right - these lights do not interfere with the lowers at all. It would be hard to show in a picture, but these lights have two wires coming from them. I soldered an eyelet onto one of the wires for ground and put it on one of the mounting bolts, so it's short. For the power wire I pushed it through the "hole" (in the lowers) that the engine guard goes through, then zip tied it to the engine guard, ran it up the down tubes and into the wire harness loop. From there it goes under the tank to the relay which is under the seat. The lowers will be able to be removed without disturbing the lights.
These particular lights are driving lights, not fog lights, so they shoot alot of light.
I was at Wallworld tonight and they have quite a selection of driving and fog lights that would work for us. The most expensive pair was $23.00. They have some that have black housings for those of you that prefer the blacked out theme too.
One more thing, I installed mine so they were "inside" the engine guards, just in case I drop the bike. Yes, I'm a member of the club.
Old Nov 7, 2008 | 09:58 PM
  #40
lmb1485's Avatar
lmb1485
had 'em on another bike.mounted 'em on the highway bars.easy to adjust and really bright
