Zippers Muscle Engine Kits
Texas - I hadn't read your post until just now. My builder called me during the build to tell me that after buttoning it all back up, he wasn't happy with the amount of valve-train noise. He ended up ordering a set of some kind of special anti-pump lifters that some guy makes (don't know his name right now). He tore it down several times and tried different things. What finally worked was a switch to HD SE cams. He said that the Red Line? cams that come with the kit just have a little too "sharp" of an initial lift and cause chatter. Even though the cams are almost identical other than that. Zippers is aware of this. They told him they had another motor doing the same thing and wanted to know what he eventually found out. He told me that he didn't think the noise would cause any harm, just that he doesn't like to send any kind of a cruiser out with any noise like that. He's pretty particular according to his reputation. I believe that now. I can find out the full details if you need any more info. Sounds like if it is still a problem, a cam switch would fix yours too.
