Jac Kinfe Highway Pegs
Old Nov 18, 2008 | 12:12 PM
badblue's Avatar
badblue
If you already scrape your boards you will do it a hell of allot more when you add 3/4 of an inch to the bottom. Also they look very dangerous if you have to make an evasive maneuver in an emergency situation (4 inchs of metal sticking out from your floorboards).
Old Nov 18, 2008 | 12:18 PM
Baffler1's Avatar
Baffler1
I am not familiar with these pegs but they sound interesting. Does anyone have a pic or a link to see them?
Old Nov 18, 2008 | 03:28 PM
edellavedova's Avatar
edellavedova
I have the FBI Jack-knife pegs on my 2008 Street Glide. I did the install myself - the pegs came with directions and a video explanation. The grinding was more than I expected, but completely manageable for me (and I am not very technically experienced).
The pegs provide some good foot positions, but still don't allow for a complete stretch of my legs.
Old Nov 18, 2008 | 09:34 PM
rizzo's Avatar
rizzo
Take a look under your floorboards. The black tube supports extend down farther than the pegs do. The supports drag before the jac knife ever will.
Old Nov 18, 2008 | 09:50 PM
rizzo's Avatar
rizzo
Originally Posted by MODCOBRA
Looking forward to the review. Am very interested on how easily the fold back up?
There is an adjustable ball/spring so you can make them tighter or looser. Mine are just tight enough to remain extended at highway speed. I want them to be able to swing in with minimum effort to avoid it being a pivot point when it would contact the ground r an evasive maneuver.
While riding, you want to be able to slip the toe of your boot under the floorboard and pull it open. If the tension is too tight when you try to "pull" it open your foot can slid down and catch the road and get twisted back and under the floorboard. Don't ask me how I know. With it adjusted correctly it will pop open easily into position. My bike is very low and this is not nearly the issue on a stock height bike.
Old Nov 19, 2008 | 04:31 AM
MODCOBRA's Avatar
MODCOBRA
Thanks for the info. That is very helpful.
Ben
Old May 11, 2010 | 03:21 PM
Epiper's Avatar
Epiper
6th Gear
Originally Posted by americanthunder
I am looking for a jac knife highway peg set-up. I know that FBI makes a set and that the other company that makes a set is called IBT. I saw a set once that didn't looked added on. They actually came flush with the bottom on the boards. I did a search on the forum and a product called peg boards came up? Interested to see what these look like? Couldn't find them anywhere? I guess does anyone else know of a similar product to the FBI jac knife pegs? I am more interested in a full board than having to cut and grind my current boards. Thanks
They are actually call IMT (www.imtnebraska.com) they do install for free. I noticed them on the Iron Aces web site for 10% off now through the 15th of this month.
http://www.ironacesspeedshop.com/pro...ighway-peg.cfm
04FordHarleyF250
Jun 13, 2019 05:49 PM
johnoconnell2015
Screamin Eagle CVO Models
May 27, 2016 07:27 AM
vtwinhd59
Jan 12, 2012 11:40 AM
wildbill118
May 11, 2011 06:24 PM
Dave_E
Mar 31, 2007 07:55 PM
