extended front brake lines!!!
Old Nov 30, 2008 | 01:55 AM
rakanghoth's Avatar
rakanghoth
Default extended front brake lines!!!
Hi guys, I have a 08 SG with ABS.... I'm trying to install a custom 18" apes handle bars... to do so i have to find a long enough brake line that connects to the peice witch distribute the flow (the pressure) to the 2 brake calibars...as for the stick brake lines ill have to replace all the brake lines including the split to the 2 calibars and its lines as all the lines are welded to that peice....does any one know where can i get long enough brake lines that connect to the dual disc calibers???
I think the propper messures i'd need is around 38"-40" from the top of the handle bar til it reaches the point where it splits to the 2 calibars...
Please help!
Old Nov 30, 2008 | 08:12 AM
The Breeze's Avatar
The Breeze
Try Magnumshielding.com I just bought some for my Roadking to install some 518s on this winter.
The Breeze.
Old Nov 30, 2008 | 08:21 AM
SG 1's Avatar
SG 1
The Breeze.
+1 I put the chromite IIs on mine.
Old Dec 1, 2008 | 04:01 PM
07FLHRCMarinePatriot's Avatar
Ditto on the Magnums. Their site is real easy to navigate to the right lenths too. I got them pretty dang cheap (after much shopping around) at www.mandmcycles.com . You'll first need the part # from Magnum's site to make it easier.
Slow&Low
EVO
21
Dec 9, 2014 10:38 PM
perpulreaper
EVO
Jul 20, 2009 09:00 AM
motordrum
May 9, 2008 09:33 AM
David F
Aug 28, 2007 10:04 AM
Billyjax
May 24, 2006 01:29 AM
