Wheel Bearing removal/install
Old Dec 5, 2008 | 02:19 PM
timvan's Avatar
timvan
Default Wheel Bearing removal/install
Just got my chrome 09 wheels
Whats it take to get the bearings removed then reinstalled? Can it be done without HD specific tools...non ABS
Old Dec 5, 2008 | 03:34 PM
Northside's Avatar
Northside
Unless they changed for '09, you need special tool for this from 2000 up sealed bearings.. JIMS makes a good one. The dealer can do it for you reasonably if you don't do it often enough to justify buying the tools.
Old Dec 5, 2008 | 03:53 PM
GasCan's Avatar
GasCan
I have a puller kit for the bearings but IMHO, I never reuse bearings once they've been pulled. New bearing kits are available from the dealer and ensures you aren't going to reinstall and get one that screws up. I'd hate to hear someone crashes because they used an old bearing so buck up for a new set.
Old Dec 5, 2008 | 04:08 PM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
Exactly what Glideman said... , $20 a piece list.
Old Dec 5, 2008 | 04:46 PM
extech's Avatar
extech
don't screw with 'em, buy new ones and have the dealer install them, if you bought HD brand wheels they should offer an installation kit that will contain the bearings and the appropriate spacers.
Old Dec 5, 2008 | 05:19 PM
dawg's Avatar
dawg
Go get a dynabolt (concrete sleeve anchor) the right size to fit inside the bearing.
Tighten the dynabolt so that it grips the inside of the bearing and then drive the
bearing out from the opposite side.
Attached Thumbnails Wheel Bearing removal/install-dynabolt-5f02.jpg
Old Dec 5, 2008 | 05:22 PM
anubisss's Avatar
anubisss
Good info here. Thanks Dawg...
Old Dec 5, 2008 | 05:25 PM
jag1886's Avatar
jag1886
No more than it costs have your local indy do it. It does require special tools and they have to mic out properly when done. My indy had no problem at all with reusing bearings that where almost new.
Old Dec 5, 2008 | 06:15 PM
hawg08's Avatar
hawg08
I would NEVER re-use a wheel bearing. I worked at a Big Dog dealer once that did a lot of sending out stock Harley wheels for choming. They tried it once and it was nothing but a headache. Of course the dummy that put them back in beat on them with a hammer!!! After that little evolution they bought a tool to install them properly but never re-used them even after that. They're not that much and it saves you from having problems down the road. You'll probably have to grind/scrape the chrome out of the bearing cradle if there's any in there after the chrome job.
Old Dec 5, 2008 | 08:22 PM
08KING's Avatar
08KING
Dawg,your still the man
