Wheel Bearing removal/install
Old Mar 1, 2009 | 01:37 PM
MadMaxxx's Avatar
MadMaxxx
Stage I
I know this topic has come up before and many have had questions.
So here is from (one) bearing Mfg.
http://www.goallballs.com/Bearings_seals.asp?page=WBK
REMOVING WHEEL BEARINGS:
When you knock a bearing out of a wheel, for chroming, powder coating, etc., you are fundamentally destroying that bearing. In fact, there's no other way to get it out without destroying it because it's pressed in on the outer diameter but access to the bearing is from the inner diameter. So you're putting an impact force across the ***** of the bearing, which damages it. It's called loading across the bearing races. You're putting little microscopic dents into the ball and the race, and over time they get aggravated. The technical term is brinelling; when you put a shock force on an outer race to an inner race across the *****, that's what you get.
Brinelling refers to a material surface failure caused by contact stress that exceeds the material limit. This failure is caused by just one application of a load great enough to exceed the material limit. The result is a permanent dent or "brinell" mark. It is a common cause of roller bearing failures, and loss of preload in bolted joints when a hardened washer is not used. Engineers can use the Brinell hardness of materials in their calculations to avoid this mode of failure. A rolling element bearing's static load rating is defined to avoid this failure type. A similar-looking kind of damage is called false brinelling. This occurs when contacting bodies vibrate against each other in the presence of very small loads. The results is a finely polished surface that resembles a brinell mark but has not permanently deformed either contacting surface.
Old Mar 13, 2009 | 06:50 PM
Focke66's Avatar
Focke66
Originally Posted by turbo54
Ha Ha I have seen evey thing now. Never push on the inner bearing cage only the outer cage of the bearing.
I think he is using that to remove them, so they are trash then anyhow.
Old Oct 7, 2013 | 06:16 PM
Punjabi Rider's Avatar
Punjabi Rider
I think he is talking about pulling them out and you have to pull on inner cage regardless which tool you use.
Manfire
Aug 18, 2015 10:49 PM
bigheadted
Mar 29, 2015 09:48 PM
Ridewva
Wheels/Tires
14
Jun 19, 2013 08:39 PM
zannydo
Dec 20, 2009 05:05 PM
2007fxdc
Wheels/Tires
Jan 15, 2009 12:40 PM
