Molex Connectors
Old May 16, 2012 | 11:30 AM
vvenator's Avatar
vvenator
5th Gear
did you have any issues? still can't get my molex secondary lock to push down.
Old May 18, 2012 | 06:31 AM
TUCCI's Avatar
TUCCI
Originally Posted by harley1425
The correct way to remove pins from a molex connector is with a pin removal tool. They can be bought at radio shack or any supply place for electronics. Harley sells a tool but like all HD stuff it is expensive.
Yeah I tried to find a drill bit small enough to fit in the molex and went with a sewing needle. Not a biatch but came close. All the wires finally came out. Found that if the wires release but wont come out the back of the molex to gently twist the wire in a clockwise or counterclockwise rotation. The wire connector is square at the base and if it twists while releasing it wont come all the way out...resist the temptation to yank. Soldering was cake, staggering the splice as not to cause a bunchup which will make it really hard to pull thru. After all the splicing and heat shrinking, I used larger heat shrink instead of electrical tape to cover the wiring and applied heat to make it mold and not come loose when I pull.
Old May 18, 2012 | 10:20 AM
TUCCI's Avatar
TUCCI
Originally Posted by mountian man
on my 09 Ultra I am putting 575 Wild 1 bars on it,on the right side I extended all the wires,my problem is I cant find my diagram for the color coded wires for the 12 wire Molex connector,which wires go in which hole putting the end back on,Please someone send me a picture...BTW ,I looked at the ken and Judy website and didnt help,Please help ,,,jposey101@aol.com
Ive got hand written diagram for my 2011 molex connectors, if you need me to scan and send em to you I can do that but I will need till next week because my modem or internet connection is on the fritz as well as my AC here in az is also on the fritz and Ive got my hands full.
Old May 18, 2012 | 01:17 PM
bagman1's Avatar
bagman1
Has anyone found that some of the wire color codes between main harness and control harness and the schematic dont match? Example the brake light switch is supposed to be red with black tracer, but my wire on the control is red with yellow.
Old May 19, 2012 | 05:56 PM
TUCCI's Avatar
TUCCI
I just finished with my Santee 14" ape installation and the most difficult part of fhe whole process was getting the molex connectors internal plate to rise to its highest level in preparation as well as getting the molex to release the wires. Now Im still waiting to install my extended brake line kit from the front brake lever and the front wheel calipers, but Im going to venture a guess that it still wont be anywhere near as problamatic as the molex connectors.
HDF Tech
Jun 8, 2011 07:30 AM
DeneFXDWG
Mar 30, 2011 09:20 PM
All Aces
Mar 29, 2011 09:23 AM
BluBob
Oct 12, 2008 08:10 PM
dustinw58
Jan 12, 2008 08:04 PM
