Ignition Module - EVO
Old Apr 10, 2006 | 06:26 PM
V2 Bagger's Avatar
V2 Bagger
Default Ignition Module - EVO
Installed a Dyna 2000 ignition module on the Glide today. Anyone else run one of theese? I replaced a 1998 Sportster 1200 module that the first owner had installed. In hind sight I could have just plugged in the box and ran it. I followed the setup procedure specified in the directions. I marked the timing plate before removing it to get the engine on TDC, and when the job was done it was in the same place. At least the timing was correct. Install only took 30-45min.
I dont feel any real improvement other than its real snappy and has improved throttle response. We'll see what it will do for my fuel mileage.
Is it "normal" for a bagger to lift the front end on 1-2 shift??[sm=smiley20.gif]
V2
Old Apr 10, 2006 | 09:10 PM
springer_'s Avatar
springer_
Default RE: Ignition Module - EVO
ORIGINAL: V2 Bagger
V2
It only lifts it on the 1-2 shift?? I'd get that looked at .........
LDR
Jun 28, 2019 04:27 PM
Rocket-Bob
EVO
21
Feb 22, 2013 02:30 PM
HarleyGyrene
EVO
Feb 6, 2012 06:18 PM
jwsullivan1981
Feb 4, 2012 08:36 PM
timberjack
Ironhead
Apr 19, 2011 05:52 AM
