Time to Change Tires?
Old Dec 14, 2008 | 10:44 PM
jcbpa's Avatar
jcbpa
Default Time to Change Tires?
Bike is going in for some tranny work and cam change. It has about 11,000 miles on it and the rubber seems pretty good. How many miles is average on tires? I don't spin them hard and I don't stop hard unless there is a deer in front of me. I've heard anywhere from 8-15... I wonder if I should bite the bullet and change them out now and not worry about it in the middle of the riding season. If I do change I'll keep the wide white wall, so that probably limits my options. Any help or thoughts are appreciated.
Old Dec 14, 2008 | 10:46 PM
ramnj's Avatar
ramnj
I personally would wait until they need to be changed, unless the work your having done requires the wheels be to be removed...which it doesn't sound like it does.
Old Dec 14, 2008 | 10:48 PM
jcbpa's Avatar
jcbpa
Nah, he's not going near the wheels, good point. Dumb question.
Old Dec 14, 2008 | 11:30 PM
soos's Avatar
soos
On average a rear tire would go about 12500 miles or better and a front 22500 or better. Check your wear bars on the tires.
Old Dec 15, 2008 | 12:23 AM
BadPiggy's Avatar
BadPiggy
I say change the tires when you see the air.
Old Dec 15, 2008 | 06:04 AM
Uncle Scrooge's Avatar
Uncle Scrooge
Tread depth and tire age is what matters. Buy a tread depth gauge. About $3 at the local auto parts store or $29.95 at HD dealership. Change at 2/32. You need that much tread to clear water and prevent hydroplaning.
Old Dec 15, 2008 | 06:11 AM
JayStronghawk's Avatar
JayStronghawk
Thumbs up Yep Agreed
That says it all right there as well as the other point if were removing the wheels then might consider it a little early ...
Old Dec 15, 2008 | 06:19 AM
1flhtk4me's Avatar
1flhtk4me
I was able to get 15700 out of the stock rear.When replaced the depth was almost at the min.
I still have the stock front with 33000 mi.
Should you change them?Depends on the tread depth,age,signs of cracking.
Old Dec 15, 2008 | 06:24 AM
jcbpa's Avatar
jcbpa
Thanks that helps a lot. I'll wait. I do have a tread depth.... duh, imagine thinking of using it.
Old Dec 15, 2008 | 06:28 AM
classic53's Avatar
classic53
15700 on one tire? Wow, that's great! I had to change my rear with about 8500 on her. It now has a little over 16000 and it will be due by riding season. Front tire is still like new. But I don't ride hard. Just a lot of 2-up riding.
Ride safe and keep the rubber side down
07 FLHTC rider
