Passing Lights
Old Dec 22, 2008 | 12:15 PM
Raaze07's Avatar
Raaze07
Originally Posted by StreetGlider57
How useful are the touring passing lights? I'm concidering them for my Street Glide, but I don't want to spend the money if they're just so much Bling. I don't ride that much on dark country roads, but when I do, the SG's single head lamp doesn't really light up the road ahead of me.
I added them to my Street Glide and outside of the cruise control they were my favorite add. They light up the street like you wouldn't believe, I highly recommend them.
Old Dec 22, 2008 | 12:19 PM
iclick's Avatar
iclick
I have an SG and opted not to add the passing lamps, although there are many possibilities available with them. In stock form they work only with low-beams and can handle only moderate increases in output without using a relay. With a relay you can use high-output pencil beams (e.g. CCI #15085 or #15086), etc. and wire them to high-beams, low-beams, or both.
I had the 37.5W lights on my old RK and they worked very well wired for low-beam only, but I had to add a relay because the total lighting-circuit amperage exceeded the breaker's capacity when an 80/100w headlight bulb was used.
The stock non-fluted headlight is IMO big on bling, small on light output with a very weak pattern. Based on previous experience with European-code headlights on cars, what I decided to do is buy a Hella E-code headlight and an 80/100w bulb, about $45 plus shipping. Check out this thread and scroll down six messages to mine where I go into the details with links, etc. I installed an 80/100w bulb in the stock headlight the day I bought the bike, but adding the Hella headlight 18 months later made a big difference in pattern and output, both on low- and high-beam.
Old Dec 22, 2008 | 12:23 PM
craigcrewcheif's Avatar
craigcrewcheif
I added the HD passing lamp kit on my 09 SG. I really like the added output plus if your main headlight ever goes out you still have some light until you get home.
Old Dec 22, 2008 | 12:28 PM
iclick's Avatar
iclick
Originally Posted by DGlide04
Anytime I ride my RK the passing lamps are on. They not only help you see at night, but more importantly, they help the daydreaming drivers see you during daylight hours. If I bought a SG, they'd be the first thing that got added.
When I had my RK I experimented with some friends by riding the bike down the road in daylight and observing the light output with high-beams (no passing lamps) vs. low-beams with passing lamps. I had 37.5W pencil beams on the passing lamps at the time which were much brighter than stock. Using 80/100W bulbs the high-beam was more visible even though only one light was working vs. three. Everyone present agreed on that, but YMMV. I later added a modulator (high-beam only) and high-beam now is an even more visible option in daylight.
Old Dec 22, 2008 | 12:30 PM
TampaJim's Avatar
TampaJim
I use moto lights with amber bulbs mounted on the brake calipers. They look like they are part of the bike and are very noticable to those folks thinking of pulling out in front of me.
Have not had a left turner or pull-out in the four years I've been using them and I ride about 24k per year.
Old Dec 22, 2008 | 12:37 PM
iclick's Avatar
iclick
It is very unlikely both high- and low-beam filaments in the headlight will go out at once, and the passing lamps are on the same fuse as the headlight. So, if the fuse blows everything on the lighting circuit goes dark, including the passing lamps, running lights, etc. However, if the headlight bulb breaks, which would also be unlikely since it is well-protected, the headlight would be dead yet the passing lamps would still work.
ssihogdog's Avatar
ssihogdog
Don't have a street glide, but the lamps were at the top of the list on my 04 RK Custom. Besides additional side vision, felt they were imperative to help cagers see me.
Old Dec 22, 2008 | 02:35 PM
FastHarley's Avatar
FastHarley
Former Sponsor
HID in all 3. Hi/Lo in center and single 35 watt in each side light. Works well.
Old Dec 23, 2008 | 07:44 AM
captsam54's Avatar
captsam54
Originally Posted by Harleypingman
The passing lamps are a definite improvement in the lighting.
You should also consider the HD fog lamp kit. $135 list for two 55W halogen bulbs; nice chrome; mount on the engine guard. Much more light, especially laterally, than the passing lamps.
What he says...!!! I got mine off eBay for $110.00 and they look awesome coming down the road at you.. A triangle of lights is way more noticeable and different than the standard passing lamps.. You wont regret it.. I have mine wired with the high beams too..
IF my headlight burns out etc. The fog lights are on an independent fuse/switch.
I also put a $13.00 Sylvania HID style bulb in the main.. You will love that.. Much Brighter..!!!
Old Dec 23, 2008 | 07:57 AM
robbie52's Avatar
robbie52
Ride with mine on all the time. Changed out the fluted lenses for clear lens, now have to modify circuit so they stay on when bright light is on.
