Running wires through bars
Old Dec 30, 2008 | 10:12 AM
ranger56528's Avatar
ranger56528
I used Mech wire and elec tape...after I had everything a part took about 10 min to run the wires thru...
Old Dec 30, 2008 | 05:48 PM
jag1886's Avatar
jag1886
I have done this many times, the only real secrets are, make certian the holes in both ends of the bar are large enough for the amount of wires your are going to drag throw them and make certian you debured the holes, when you make up the loom don't make all the wires the same length, you want to have several differant length wires so you aren't trying to drag the entire thickness through at once and make certian you use plenty of lube, I use WD-40 and spray it down the inside of the bars and spray down the harness and don't use string use mechanics wire because some times you have to pull pretty hard to get it throw, I can't imagine string working very well.
Also make certian you solder and shrink wrap everything this is not a job for butt connectors!!
Old Dec 30, 2008 | 08:58 PM
turbo38sfi's Avatar
turbo38sfi
First of all...if you're going to go through the trouble of doing this, ditch the stock bars!
I've done this with a set of Wild1 Chubby bars and it's not a bad job at all. I even had to extend my wiring..just took my time and soldered everything. It takes patience but is not difficult. I think it may be tougher on a stock diameter bar though..it was fairly tight on the thicker chubby bars, the stockers I can see being a pain. Spend the 150 on a set of bars, do the internal wiring and you'll be stylin'
Old Dec 30, 2008 | 09:55 PM
Wally's Avatar
Wally
I have the Wild one 575's on my bike as well and although I agree with the above post, you don't need to extend the wires. Just disasemble the plug and find a different route inside the fairing and you'll be good to go.
Old Dec 30, 2008 | 10:43 PM
rdurantb's Avatar
rdurantb
Did this on my 07 RK, which has stock HD reduced reach bars. My bike has cruise control which means lots of wires. Several ways to pull the wires through the bars, talcum powder, tape, etc. The hard part for me was cutting the wires in the area of the headlight, which I did to gain some extra length and to simplify the operation. (I didn't want to disconnect the wires from the switches.) I believe an aftermarket shop now has an extension kit for this(Kurykayn?). Soldering is not difficult, I made a simple jig (to hold the wires while soldering.) With shrink tubing the job can be done simply enough. I also used auto connectors when I put in the wire extension in case I wanted to switch bars in the future. All wires are color coded and easy enough to cut, put in extensions and re-connect. Just take your time.
Old Dec 31, 2008 | 10:31 AM
joker1450's Avatar
joker1450
I run the wire in my wild chubby with the help of "borotalco".
RKC 2008
clap
Apr 5, 2017 08:07 PM
Powertrip240
2014-2024 Touring Models
27
Mar 16, 2016 07:38 PM
Airborne314
Apr 23, 2010 11:50 PM
IAFatBoy96
Apr 12, 2010 06:02 PM
bajabob
Apr 23, 2006 09:52 PM
