Jackpot Slip-ons
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
1. Sound - thumbs up for me. Pretty much perfect.
2. Power gain - excellent. As advertised.
Now I do have some quality issues and in all fairness Jamie did attempt to correct the problems.
1. When I first got mine the right pipe turned yellow at the baffle head. Jamie sent me a new muffler with a heat shield. Apparently I was running a bit rich and letting off the throttle was allowing air in the pipes and igniting the unburnt fuel combined with the baffle head being a hot spot. I ended up tearing down the entire exhaust system and using Ultra Copper on every joint. Problem still was not solved. After a couple thousand miles I found the location of the leak because of carbon marks. It is the slit for the clamp at the head of the muffler. Well the solution is to push the muffler all the way forward. The problem with this is that now the right muffler is fully an inch forward of the left muffler pushed all the way on. Eventually I found a compromise position where it is not so noticeable. The compromise position takes a crap load of Ultra Copper on the right to get them to seal. Not real happy with fit and finish.
Problem number two:
The baffles work loose. At first I thought something had rattled loose on my bike. Every time I stopped there was an awfully loud rattling sound. After a few weeks I figured out it was the left baffle. I called Jamie and they told me it happens and to take the baffle out and put a couple of pings in the front of the baffle which I did. Unfortunately I had to use a block of wood and a hammer to get the baffle back in. In the process of doing that I slightly damaged the shell of the pipe. Apparently my block of wood was a little harder than I thought. Now it is kind of annoying to look at. Just recently the right baffle started rattling. I'm dreading taking that one out. I kind of just want to ride the thing.
At any rate Jamie may already have these issues worked out. I was a very early Jackpot customer. Actually I believe I was the first guy to order them. When I have contacted Jamie he has been helpful but still a year later I am a bit frustrated.
Ron
Problem number two:
Ron
Problem number two:
Ron
I already had the SE air cleaner so I just ordered the PCIII and the Jackpots. I also want to say that the system has performed as advertised and Jamie took the time to do custom maps for my bike after the running rich stuff.
I am not railing on Jamie at all, He in my mind is an honest business man. I am frustrated with fit and finish and he may already have these issues worked out. I really debated on whether to write this or not but felt I should put it out there. As I know all to well when developing a product there are going to be unanticipated problems and at some point you have done all you can do to make a situation right. I do know Jamie is upside down with working on my problems already and you don't stay in business if you do too much of that.
