Throttle Problems
Old Dec 30, 2008 | 04:38 PM
ASHEroadking's Avatar
ASHEroadking
6th Gear
Question Throttle Problems
Have a question about a sticking throttle. I have a 1998 Road King Classic. When the throttle is turned open, it closes very slowly. Am I missing a spring behind the air intake to assist witht hte closing, or ? I can't seem to find and referrence on the internet. Any help will be great.
Old Dec 30, 2008 | 04:49 PM
jag1886's Avatar
jag1886
I would first lube the cables and then make certian they are adjusted properly. I have had both cause that problem.
Old Dec 30, 2008 | 07:46 PM
ASHEroadking
6th Gear
Have sprayed WD-40 down the cables at the grip, helped alittle. Is there a suppose to be a spring behind the air filter housing? I have one little spring back there, but it looks like there is a place for another spring.
Old Dec 30, 2008 | 07:51 PM
stafford's Avatar
stafford
you might try loosening the switch and throttle housing and seeing if you can slip it just a little toward the end of the bar. often the end of the bar will scrub on the inside of the throttle grip.
riverdawg1
Oct 14, 2018 03:44 AM
Atlaska
Sep 17, 2014 03:07 PM
bagman1
Mar 2, 2013 09:04 AM
swomack
Sep 15, 2006 11:51 PM
philly_night_train
General Topics/Tech Tips
Sep 27, 2005 10:09 AM
