oil temp sensor problems
Old Jan 3, 2009 | 04:59 PM
bikerbehaviorist's Avatar
bikerbehaviorist
Default oil temp sensor problems
Went to pull the plug next to the drain plug and have stripped the torx pattern. Any ideas short of pulling the oil pan to get the plug out? I have tried a bigger torx - too big and a allen no luck. There is not much room there to get a impact wrench or much else.. Thanks in advance for any help
Old Jan 3, 2009 | 05:32 PM
jeff194's Avatar
jeff194
I had to heat the pan in the area just below the plug to get mine out when I installed my oil temp sensor. After heat it came out pretty easy. If you can get something to fit in there I would try heat also. You may be able to grind down an oversize allen, or a small chisel / screwdriver, and try backing it out that way. Some one else here once recommended tack welding a nut on the plug, and use that to back it out. Good luck!
Old Jan 3, 2009 | 07:35 PM
ucommbxny's Avatar
ucommbxny
try a little heat and a easyout
Old Jan 3, 2009 | 08:10 PM
G wizz's Avatar
G wizz
Now how the hell did you do that ??
If all else fails, drain your oil pan, drill the plug in the center, and use an easy out to remove the plug. Be sure to heat up the area around the plug first though, as H.D. uses red locktite on those threads.
Old Jan 3, 2009 | 11:02 PM
soos's Avatar
soos
Unless they changed it for the '09's, that plug is a 5/16 allen socket not a torx.
Old Jan 3, 2009 | 11:11 PM
TODDNVAL's Avatar
TODDNVAL
You could buy the adapter kit to put the oil temp sender at the oil filter.
Old Jan 4, 2009 | 07:10 AM
HDV-GLIDE's Avatar
HDV-GLIDE
+1 on that...Need to use the right tool for the job at hand...I removed mine with a 5/16 allen socket using a 1/2 ratchet.
Old Jan 4, 2009 | 10:46 AM
bikerbehaviorist
Thanks all I check and re-checked and it looked like a 40 torx to me... but that is not the issue now.... I will bring it to a friend with a table lift so I am not laying on my back and see what we can do - I like the idea of grinding down a a bigger allen I have a cheap set that I can steal from - keep you posted. But first a frigid ride this am it is in the 30's in N. Cal.
msocko3's Avatar
msocko3
Right on using the right tool. I've done this on 3 bikes, 2 06's and a 09' and all have been allen and all have come right out with no struggle. The crap that the MoCo uses which looks to be red loctite is not as strong as the red loctite.
Old Jan 4, 2009 | 11:33 AM
bikerbehaviorist
Ok now that we have confirmed that I used the wrong tool I think the admin should demote me back to newbie :-) :-) :-(
