Bags vibrating??
Old Jan 15, 2009 | 09:22 PM
NewHarleyGear's Avatar
NewHarleyGear
Make sure your not missing one of the rubber rail mounts on the underside of the bag.
Old Jan 15, 2009 | 09:26 PM
Beemervet's Avatar
Beemervet
Also, remove both bags and CLOSELY examine all of the hardware and mounting system. Excessive vibration is very destructive.
Old Jan 15, 2009 | 09:56 PM
JohnScrip's Avatar
JohnScrip
Several years from now, you'll hear a bunch of squeaking - Not unlike an old bed, coming from behind you. It'll be very loud, very annoying and you'll think that something is about to fall off the bike at certain speeds.
It'll probably start when you're a couple hundred miles from home and you'll be wondering if one of your saddlebags are going to jump off the bike while you're on the highway.
Dark thoughts may soon enter your mind while the squeaking slowly drives you mad and passively whittles away at your will to live. Don't give in to them. Don't let the squeak demons ruin your life.
Pull into a gas station and get a tube of graphite in a liquid suspension - Lock thaw perhaps.
Take the bags off and squirt a little of the black gold wonder liquid on the rubber mounts where the bag rails bolt to the muffler mounts. Because it's not the bags - It's that rubber mount hardening and making an incredibly bad squeaking noise against that little metal strip.
Have a little coffee, get back on the bike and forget your worries once again.
And maybe nip it in the bud before it ever happens with a drop or two of molybdenum in a liquid suspension a couple times a year (Bike Slide - I think it's called Bike Slide - is a moly-based cable lube that works wonders). I hit those mounts pretty much every time I really *wash* the bike.
Sorry - didn't mean to derail the thread - But it's kind of like prostate problems - Some of use are just going to have them and ignoring the problem won't make it go away. But unlike most prostate problems, this irritant can be prevented.
Old Jan 15, 2009 | 10:43 PM
Texas bagger's Avatar
Texas bagger
John
The advice for down the road is good and much appreciated.
Old Jan 16, 2009 | 08:11 AM
mainshaft's Avatar
mainshaft
Check the mounting hardware, I noticed mine vibrating and rubbing a few months after I bought it, both sides rubbed throught the paint into the fiberglass, harley replaced both bags for free.
streetglidekid09
Aug 21, 2016 11:11 AM
RBJones
Apr 14, 2012 12:51 PM
Mississippi Birdman
Dec 9, 2011 01:15 PM
Mississippi Birdman
Sep 25, 2011 07:59 AM
jd140400
Apr 23, 2008 08:59 AM
