fixed that annoying vibration
Old Jan 19, 2009 | 08:19 PM
beary's Avatar
beary
Default fixed that annoying vibration
With new exhaust mounts!
Lately it seem like the vibration between 1500 to 2000 rpms was getting progressively worse. So I replace the front motor mount (it was torn anyway), but nothing changed.
That was frustrating, I'm sure that it felt better 10000 miles ago, but what else could it be?
THen the other day I notice my left V&H Oval vibrating more than my right. I turned off the motor and sure enough, I could actually move it up and down noticeably more than the right. Well it is a 2002 RKC with 25000 miles, so worn out rubber makes sense.
I replace the rubber exhaust mounts (less than $10) and now both V&Hs are rock solid, but more important, THE VIBRATION IS GONE. Finally fixed that sucker. I just never thought about the exhaust being the cause.
So when you replace the front motor mount, spend an extra $10 and ten minutes to replace those exhaust rubber mounts as well.
I do have one question, should I lock tight those bolts on the exhaust? They do have lock washers.
Beary
Old Jan 20, 2009 | 06:36 AM
glide2005's Avatar
glide2005
I put the blue thread locker on every bolt I take off and then replace. Its a no brainer on a Harley.
NH_DRZ
Jun 25, 2019 09:12 PM
ZEROPILOT
Jun 6, 2019 03:52 PM
masplumber
Aug 20, 2016 06:02 PM
Tim "the drifter"
Sep 3, 2013 09:35 AM
Slu
Dec 7, 2012 11:17 AM
