Pc iii
Thanks
If you have TBW ('08-'09) you may not need to set the TP, but earlier bikes need it. It is simple: For the PCIII plug in the 9V adapter and turn on the ignition without starting the engine. In the TP-setup part of the software click on "Reset," then apply full throttle 'til the large number in the window settles (about a second or two), then "OK." The PCV procedure is the same except there is no 9V adapter. You'll obviously need to tether either via USB to a computer with the PC software loaded.
I think an '09 FLH requires a PCV, but since '07 and '08 will fit either I would recommend the PCV, as it is only slightly more expensive, has more features, and gives you the option of upgrading to the excellent Auto-Tune modules at a later date if desired. Fuel Moto supports and warrants the PCV for '07-'09 bikes even though Dynajet only approves the '09 line. I have an '07 SG with a PCV and Auto-Tune, purchased of course from FM, and it works very well on this bike.
If you have an '07 or '08 I would recommend the PCV, as it is only slightly more expensive, has more features, and gives you the option of upgrading to the excellent Auto-Tune modules at a later date if desired. Fuel Moto supports and warrants the PCV for '07-'09 bikes even though Dynajet only approves the '09 line. I have an '07 SG with a PCV and Auto-Tune, purchased of course from FM, and it works very well on this bike.
There are options to a PC check out the above. PC installation on an ABS equipped touring frame is not very clean and can lead to problems if you don’t pull the seat and wrap the PC in plastic wrap every time you wash the bike.
If you buy from Fuel Moto it will come preprogrammed for your set up. They will also email new setups if you change anything; very easy people to deal with.
There are options to a PC check out the above. PC installation on an ABS equipped touring frame is not very clean and can lead to problems if you dont pull the seat and wrap the PC in plastic wrap every time you wash the bike.
Anyone else have issues with the PCV getting wet on an 08 w/abs?????????????????????????
