easy home mad gps mount
Old Feb 17, 2009 | 08:14 PM
Cookiemuncher's Avatar
Cookiemuncher
Default stro1965
I took the suction cup mount and cut off the suction cup then epoxied a #10 lock nut inside,after the epoxy dries you have to drill out the center of the nut then run at tap through it....it worked but kinda killed the locking part so I used locktite
Old Feb 17, 2009 | 08:33 PM
stro1965's Avatar
stro1965
Originally Posted by bigdumbnoitall00
i saw something simialar guy had it in the center bag cut the bottom edge of bag down and addedclear plastic then would tuck the top flap behind the top of gps when in use not in use close the bag and didnt know it was there.
That's probably mine you're thinking of...
plutnicki
Nov 29, 2012 04:34 PM
KDUBYA
May 5, 2011 01:17 PM
db2753
Aug 11, 2009 03:01 PM
Mathews2
Feb 14, 2008 08:29 AM
bigpig
Sep 6, 2007 07:59 AM
