Front fork disassembly question.
Old Feb 19, 2009 | 01:48 PM
47Norton's Avatar
47Norton
Question Front fork disassembly question.
I'm in the process of installing a Progressive lowering kit on the front end of my 2000 Road King Classic. I have both fork tubes out laying on the bench. I'm having a little difficulty removing the cap screws that go up vertically on the bottom of the lower sliders. The manual say to use a air impact to loosen these. I'm at a stop right now as I have an air impact wrench, but no extended 6mm hex socket that will reach the one side. I'll get one today. My question is what are those caps screws connected to? I'm looking at the parts blowup but can't really tell by that. I'm hesitating to turn them with a normal ratchet since I don't really understand how this thing is assembled and don't want to do any damage. If someone has done this job could you please explain this to me? TIA, Roy
Old Feb 19, 2009 | 02:38 PM
stro1965's Avatar
stro1965
They screw right into the bottom of the damper assembly that is inside the lower. You can't hurt THAT but those screws are brass and the heads will strip easily. Make sure you have a good sharp allen and the air impact is so they'll break free cleanly.
Old Feb 19, 2009 | 02:39 PM
stro1965's Avatar
stro1965
Also, consider replacing with new ones (and new crush washers for sure) if they are even a little bit dinged up.
Old Feb 19, 2009 | 02:43 PM
x1rider's Avatar
x1rider
this is for a 2009 SG but I can't imagine it's that different. The 6mm screw is attached to the damper tube and there is an "oil lock" at the end of the tube (cylinder in 2nd pic). Here are a few pics I took during disassembly, I didn't use an impact wrench at all.
Old Feb 19, 2009 | 02:45 PM
dawg's Avatar
dawg
I took a 6mm allen and epoxy welded it into a socket to make one
You can also use this method if you don't have an impact
Old Feb 19, 2009 | 02:48 PM
47Norton's Avatar
47Norton
Smile
Stro, OK, I got one apart. Now I can see why the air impact was needed. I will take your advice and replace the screws and crush washers. I need to go pick up new seals so I'm hoping I can get them all at the same time. Thanks for the quick reply. Some times a little explanation is all a person needs. I'm in no hurry with this due to cold weather and didn't want to foul something up. Thanks again, Roy
Old Feb 19, 2009 | 02:55 PM
47Norton's Avatar
47Norton
Dawg and X1, Thanks for the pics. Looks like this has a happy ending. I don't think mine was coming apart without the impact. I might just chop off a hex key and put it in a 6mm socket. It'll save me a trip into town although I have felt the need for some extended hex sockets. Love those new tools. Thanks guys, Roy
Old Feb 19, 2009 | 03:04 PM
JonnyD's Avatar
JonnyD
Dawg, is that a screwdriver you're using to hold the fork? Good info, as I'm doing this very soon myself.
Old Feb 19, 2009 | 04:13 PM
dawg's Avatar
dawg
Yes, flatblade through the caliper mounting hole to hold it from turning
Spazz
2014-2024 Touring Models
53
Jan 8, 2018 11:49 PM
RadarRat
Aug 24, 2016 01:58 PM
onedae
Jul 3, 2015 07:51 PM
aftica
Oct 6, 2012 12:46 PM
London dude
Mar 27, 2009 11:13 PM
