Starter Help
Old Feb 20, 2009 | 01:39 PM
jdreed520's Avatar
jdreed520
Bump......somebody...anybody....have an idea?
Old Feb 20, 2009 | 02:13 PM
PhilM's Avatar
PhilM
Something is not assembled correctly.
I'd have a real close look at the way the jackshaft is in the coupler and how it;s installed in the bushing.
I could certainly be wrong, but I just don't think that can happen if things are installed properly.
Old Feb 20, 2009 | 02:19 PM
jdreed520's Avatar
jdreed520
Thanks Philm....i will pull it all out tonight when i get home........and thanks for your suggestion about the starter clutch assy...i will also look at this......
Old Feb 20, 2009 | 02:47 PM
robzuc97's Avatar
robzuc97
Ditto on wrong assembly... the thrust washer (and therefore the bolt) is locked in by the lockplate which is keyed to the jackshaft keyway. For it to turn loose after proper assembly would result in the lockplate tab breaking off; a 'CAUTION' is even listed in the manual for tab alignment. 7-9 ft-lbs of torque on bolt, then bend tab over on bolt flat to lock. Dunno how the clutch ($118.00 at dealer) would affect this but mine went out few months back and all starter motor did was spin without turning the engine over.
Old Feb 20, 2009 | 02:55 PM
jdreed520's Avatar
jdreed520
Thanks Robzuc97
I will pull it apart tonight.
Old Feb 20, 2009 | 03:31 PM
PhilM's Avatar
PhilM
Do not confuse the clutch you use when shifting with the starter clutch.
The starter clutch is simple a one-way (sprag) bearing that allows the pinion gear to "pull" when the starter is spinning the clutch basket (via the ring gear) during the starting event, and free-wheel for the instant that the engine fires and spins faster than the starter motor ~ until the pinion gear retracts from the ring gear.
I hope that makes sense... I can visualize what I'm trying to say perfectly... but I'm afraid something may be lost in translation...
Old Feb 20, 2009 | 03:38 PM
jdreed520's Avatar
jdreed520
Yea i know that.....i will take it apart tonight to see what i can find....
Old Feb 20, 2009 | 07:08 PM
jdreed520's Avatar
jdreed520
Ok guys......Here is the answer to the delema......I am Stupid.......it was the spline coupler.........not there.......so once i broke everything down and pulled the starter there was no coupler..........So the problem was ME not the starter.......HEHEHEHEHEHE oh well i really do thank everybody for there imput.......and you guys were right on the money...it was the jack shaft put in wrong......oh well lessons learned....
PaulBartell
Engine Mechanical Topics
Nov 29, 2018 07:48 PM
hAkron
General Topics/Tech Tips
May 30, 2016 06:55 PM
maverickwolfe
May 28, 2015 10:57 PM
Mikeduke108
Jun 20, 2014 02:46 AM
RidemyEVO
EVO
Feb 16, 2011 05:11 PM
