Fork Question
Old Feb 21, 2009 | 02:34 PM
deleontow's Avatar
deleontow
Default Fork Question
Here is a good question, I have a 98 Ultra with the 3/4 axle. Can I install the complete fork assembly off a newer bike, if I was to change out the wheel? I have an oportunity to pickup a set of chrome forks with calipers cheap. So will changing the bearings and axle out work for me or ?
Thanks
Old Feb 21, 2009 | 03:34 PM
hogbag07's Avatar
hogbag07
Are you fitting late model twin piston calipers on each side of your 1998 bike.You should only need bearings, rotors I would also fit the later master cylinder or have your early master cylinder bored and sleeved to suit.
Old Feb 21, 2009 | 04:44 PM
jdreed520's Avatar
jdreed520
It will work.......newer fork sliders use a 1" axle so i think you would only need to change the bearings in your wheel....as far as the master cylinder you need to get one off a newer bike to support the two piston calipers....but other than that you are good to go. I did the same thing on my 99, i used everything off a 2000 and it worked good.
MyClassic09
Mar 26, 2018 04:07 AM
Jackpoticorn
Apr 2, 2015 08:56 PM
goldie
Apr 6, 2014 10:04 AM
Dustmaker
Dec 4, 2008 10:24 AM
kingrupert
Nov 15, 2007 07:52 PM
