Brembo (front) Brake Conversion
Old Feb 21, 2009 | 10:58 PM
Jumpman's Avatar
Jumpman
Default Brembo (front) Brake Conversion
OK, so I had done a lot of research and finally decided to do the Brembo thing on my Pops '04 Ultra Classic.
Rather than drop all the coin on a full brake system, we grabbed a set of the silver OEM silver H-D Brembo's...the correct mounting bolts...and a pair of the H-D 'teardrop' floating rotors. Oh, also grabbed the chrome banjo bolt/bleeder kit specific to those calipers.
When I first took everything apart and did my mock-up, I discovered that the banjo bolts for the brembos will not fit thru the banjo fitting on the H-D diamondback (2004) brake lines. Also, the banjo bolt will not fit the '04 master cylinder.
We were ready to go ahead and grab a new set of brake lines, but (fortunately) none of the local H-D shops had them in stock..and we found they were on national back-order. We were also prepared to pick-up a master cylinder/clutch lever mount for an '08.
Since we could not find parts - I grabbed a 3/8" drill bit and shaed a bit off of the banjo fitting for each caliper so the newer style banjo bolt would fit. About an hour later, the system was all put together, bled and operated quite well on a short 1/2 mile test ride.
I still need to swap rotors, which will be done tomorrow - and (weather permitting) give it a 'real' test - but all seems to be well.
- note - I tried to use DOT 4 fluid at first, but I think it was too 'thin' for the 04 master cylinder set-up & opted for DOT 5...Hopefully this will not create issues further down the road (literally).
Old Feb 22, 2009 | 12:41 AM
gilbos440rt's Avatar
gilbos440rt
Should be fine as long as you flushed the master cly pretty good Got my parts off e-bay to do mine to the Brembo's (christy's harley on e-bay I got the M/cly, calibers, rotors, levers, perches, everything for $279) about a week and my small parts should be here from harley to finish the job!
Old Feb 22, 2009 | 09:54 AM
Jumpman's Avatar
Jumpman
I'll try to post some pics later when all is buttoned-up.
If these things stop as well as I think they will (based on teh short test ride with the old rotors) I'll be doing the same upgrade on my Road King when I do my 21" front wheel.
Old Feb 22, 2009 | 05:10 PM
Jumpman's Avatar
Jumpman
Here are some pics of the finshed project...
Old Feb 22, 2009 | 05:21 PM
streetglide13's Avatar
streetglide13
your pops has onenice lookin bike, jumpman. Is that a complete bolt on "kit". I want to do the same to mine soon. Looks great. Seems like a simple swap.
Old Feb 22, 2009 | 05:49 PM
harleyeglideman's Avatar
harleyeglideman
Really sharp bike!
However, you might want to research the Dot 4 to 5 swap issue. Not a good idea from my prior readings about the subject. Any residual left anywhere in the lines/ system which causes a mix of the two will create big problems. I think you need to change the lines entirely but I am no expert. Use caution.
Old Feb 22, 2009 | 06:00 PM
Jumpman's Avatar
Jumpman
Originally Posted by harleyeglideman
Really sharp bike!
Glideman,
I understand that mixing of the two fluids can cause some sort of 'crystalization' (sp?) if left mixed for a long period of time.
When it came time for the fluid, I blew the lines out with my compresor with my compressor prior to dumping in the DOT 5. Then I pushed an 1/4 bottle thru the system before wrapping everything up. Hopefully that was enough.
I took it out for about 2-miles after it was complete and I am sold on the swap...Braking was MUCH improved over the stock '04 hardware. He rode it home today, so I will follow-up with him tomorrow to see how he likes it.
Old Feb 22, 2009 | 06:26 PM
gilbos440rt
Isn't the early rotors a good bit smaller than the Brembo rotor's, if so they'll only be better once you get the Brembo rotor's on them!
Old Feb 22, 2009 | 07:31 PM
Jumpman's Avatar
Jumpman
Yep, when swapping to the Brembos we moved to the newer 'floating' rotor. Diameter increased from 13" to 13.5". Made a big difference.
Old Feb 22, 2009 | 07:36 PM
Certified Drunk's Avatar
Certified Drunk
....and you always wanted to know why your kid's have...
Your neighbor is getting a special delivery from FedEx!!!!
