need info on installing chrome front end
Old Feb 26, 2009 | 02:38 PM
wildrider's Avatar
wildrider
Default need info on installing chrome front end
going to buy h-d chrome front end, will i need anything extra to install, i know new fork oil, but do i need to buy seals etc? any help will be appreciated.
Old Feb 27, 2009 | 01:31 PM
wildrider's Avatar
wildrider
can't get any reply. surly someone knows; i just want to be sure i have everything i need before tearing the front end down.
Old Feb 27, 2009 | 01:35 PM
Akitakoi's Avatar
Akitakoi
Big job I hear, got a manual, lift, lots of tools? If I remember right you do need a special tool for something. Try to search the net, maybe more help there. The Service Manual should tell you a lot.
Let us know how it goes.
Old Feb 27, 2009 | 01:36 PM
Softail Girl's Avatar
Softail Girl
Do a search here in the forums. I asked the same question in December and got a lot of good advice.
Old Feb 27, 2009 | 01:43 PM
steveh326's Avatar
steveh326
fork oil, new fork seals and new crush washers for the bottom drain holes should do it. You need to either obtain a fork seal driver or use PVC pipe like most have done here to drive the seals in place. I split the 1 1/2" pvc pipe lengthwise and drove the seals with that, but afterwards I saw where someone made a driver out of a pvc coupler that looked like it might work better.
Old Feb 27, 2009 | 01:44 PM
brunswickoh's Avatar
brunswickoh
certainly not a big job at all, it's a simple do it yourself job. There is lots of information here in the forums and the manual explains it very clearly
Old Feb 27, 2009 | 01:46 PM
ezlife's Avatar
ezlife
You'll need 2 new fork oil seals and something to install them (piece of 1 1/2" pv), fork oil (go with heavier SE), good measuring cup oz/ml, depends how many miles might want to do bushings, loctite, 6mm hex for bottom of fork leg, crush washers for drain plugs, service manual. Not hard, just take your time. I removed mine from triple tree when I did them last year and had both done and reinstalled in 1/2 day along with some other work I was doing. Make sure oil seal seats all the way and retaining clip seats fully in inner groove. Don't overfill.
Old Feb 27, 2009 | 01:53 PM
Jumpman's Avatar
Jumpman
Agreed on the heavier fork oil. Ride is not quite as plush as from the factory...but heavier oil will cut down on front-end dive in hard braking, and gives an all around more stable feel in my opinion.
Old Feb 27, 2009 | 02:25 PM
paradirr's Avatar
paradirr
6th Gear
Not a big job at all just did my street glide. Get at service manual and you'll be all set.
Old Feb 27, 2009 | 02:35 PM
timvan's Avatar
timvan
Easy job. 2-3 hours if you have any wrenching skills at all
