PC V install question
Old Mar 1, 2009 | 11:45 AM
KY HDRider's Avatar
KY HDRider
Default PC V install question
I just installed the PC V on my 04 Ultra today. I ordered from Fuel-Moto last week. It is too cold to ride any, but I have a question. Is it necessary or advantageous to do the throttle adjustment in the software? Seems I remember reading somewhere that a pre-mapped PC V does not need this done since Jamie already set up the unit with a custom map before shipping to me. Any advice appreciated.
Jerry
Old Mar 1, 2009 | 11:55 AM
09StreetGlider's Avatar
09StreetGlider
Jerry
I believe on the non-TBW bikes such as yours it would be wise to check it. I didn't have to set mine but it is TBW and was dead on in closed position when the bike was at operating temp. I would let it idle for a bit with the laptop hooked up to the PCV and once engine temp comes up and idle goes down to normal the throttle should read 0%. If not you'll need to calibrate it. Mine starts out at 2-3% when cold and settles right on 0% once it's warmed up.
Old Mar 1, 2009 | 12:38 PM
papifun's Avatar
papifun
subscribed
Old Mar 1, 2009 | 01:07 PM
TruBluUltra's Avatar
TruBluUltra
Throttle position should be checked....it might not be off by alot, but it's wise to check anyway. I did my PC-V earlier today.....at idle, throttle position showed 4% before I reset it. I'm pretty sure the map and throttle position are independent of each other (IIRC, you can change maps without resetting TP).
Paul
Old Mar 1, 2009 | 01:15 PM
09StreetGlider
You did let it get up to operating temp before you set it right? I'm sure you did, but for other's knowledge this is important as the warm-up cycle affects TP.
Correct. The throttle setting have nothing to do with what map is installed. Changing maps has no effect on your throttle settings.
Old Mar 1, 2009 | 01:30 PM
TruBluUltra
Wink
Yep, sure did
Old Mar 1, 2009 | 05:10 PM
iclick's Avatar
iclick
It's advisable to check both TP's (0% and 100%) on any non-TBW bike. It's very easy on the PCV. First, warm-up the bike to normal operating temps. Connect to a computer with the software installed via USB cable, go to Device Tools > Calibrate > Throttle Position. Turn on the ignition but don't start the bike, then click on "Reset" and turn the throttle to 100% (WOT). Close that small window and go to the digital readout to double-check both positions on the digital meters. It should show 0% with no throttle input and 100% at WOT. If WOT shows 98-99% that's close enough. You're done!
Old Mar 1, 2009 | 08:57 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Yes, on the 07 and earlier non drive-by-wire bikes I do recommend checking and/or resetting the throttle postion settings. A simple check with the USB software is very easy, and if it reads anything other than 0% at idle I recommend resetting it. Note on these models this can be done with a cold motor as it does not have a stepper on the throttle blade.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Mar 1, 2009 | 10:35 PM
KY HDRider's Avatar
KY HDRider
Thanks for the replies. I will get the throttle position check done ASAP.
Jerry
Old Mar 4, 2009 | 11:57 AM
JustDennis's Avatar
JustDennis
What about on an 08? Maybe the instructions will tell me but was wondering if I needed to set the TP 0% and 100% when I install mine. SHould be here from Fuel Moto tomorrow (I Hope).
