I just want to let you know.
1. Get a new drill bit
2. Use a putty knife to hold the weather seal up to drill out the rivets.
3. You will have to drill out the holes on the tour pack due to screws are a little bigger
4. It is alot easer if you have someone help to hold the lid while drilling
5. Drill slow.
Then enjoy they make a huge difference in looks.
Good luck.
3. You will have to drill out the holes on the tour pack due to screws are a little bigger 4. It is alot easer if you have someone help to hold the lid while drilling
5. Drill slow.
Good luck.
Its actually a whole lot easier if you dissemble the old style strap hinge pin, then you can set the lid on a stable surface for drilling.
It is a two piece pin that you hold one end with a #25 torx and unscrew the other end with a #15 torx.
After removeing the screw from the teather strap close lid and dissasemble hinge pin, then lift entire top all at once.
Fits '06-later FLHTC, FLHTCU, FLHTCUSE3/4 and FLHTCUTG models. Fits '06-later Touring models equipped with Color-Matched King or Road GlideŽ Tour-PakŽ Luggage. Does not fit Chopped Tour-PakŽ Luggage.
Did mine yesterday, just drilled the old ones off while it was on the bike, didn't take it all apart like HD wanted. 4 hands would have been nice but you can do it with 2. Take your time and enjoy the new look when your done.
