List for Cam Change
Old Mar 3, 2009 | 04:08 PM
up2nogood22's Avatar
up2nogood22
Default List for Cam Change
What exactly do I need on hand to do install a set of Andrews 26H Cams?
Bike is an 08, so will not convert to gar drive at this time.
Cams
Adjustable Pushrods
Gasket
__________?
___________?
___________?
Old Mar 3, 2009 | 04:16 PM
dawg's Avatar
dawg
You cutting the p-rods and using e-z install or pulling the tank?
Were it me, especially with the ease of pulling an 08 tank, I'd save my money and use the stock rods. You'll need some Timken B168 bearings, HD cam service gasket kit (don't use the inner bearings that come with it, use the Timkens), and the necessary tools.
Old Mar 3, 2009 | 04:42 PM
stro1965's Avatar
stro1965
FYI- I specifically told the shop that I did NOT want the cam service kit. I was supplying my own bearings and using adjustable pushrods so all I needed was a few gaskets. Saved about $40.00.
Also, I replaced my lifters, most seem to think it's a good idea.
Old Mar 3, 2009 | 06:24 PM
jag1886's Avatar
jag1886
Take it to the dealer they are still running there 15% discount on parts and labor.
My dealer charged me $230.80 parts and $259.00 labor to do the job.
I think $259 is pretty darned cheap to put in a set of cams.
Old Mar 3, 2009 | 06:26 PM
fxlowboy's Avatar
fxlowboy
cam gear locking tool Georges garage tools #320620
oil pump adjustment screw #320530
1 spacer for cam sprocket aligment HD #25729-06 0.100
#25731-06 0.110
#25734-06 0.120
#25736-06 0.130
#25737-06 0.140
#25738-06 0.150
Old Mar 3, 2009 | 06:29 PM
fxlowboy's Avatar
fxlowboy
spacer washer for cam sprocket aligment
Old Mar 3, 2009 | 06:30 PM
dawg's Avatar
dawg
Just in case anyone didn't know, HD #94076-09 is only $34.95 which is cheaper than Georges, plus even cheaper if you get it at a 20% dealer.
Old Mar 3, 2009 | 08:59 PM
cooper57M's Avatar
cooper57M
Keep us informed of your progress. I was thinking doing the same for my 08 SG. I have been trying to find out if the bolt in cam is actually bolt in. Will it work with the stock ignition? Will it affect idle, closed loop at idle and cruise etc.
Old Mar 3, 2009 | 09:04 PM
dawg's Avatar
dawg
Bolt in is just that, bolt in. Works with stock components (ignition, etc.) and doesn't affect cruise, etc.
Old Mar 3, 2009 | 09:17 PM
nemick's Avatar
nemick
As mentioned above, changing out the inner cam bearings to the Torrington type may be a good. However, if you're planning on doing this yourself, you may find the cost of the special tools required to change the bearings may be prohibitive.
