FLTR Headlight Adjustment
Old Mar 3, 2009 | 06:48 PM
boogiewithtuck's Avatar
boogiewithtuck
Default FLTR Headlight Adjustment
Have my measurements laid out, cross target on wall, $4.5MM$ deep-well socket and repair manual in hand. I need to adjust the heigth of both beams, they are too low. Do I actually have to turn both the left and right adjusters simataneously to accomplish this?
I tried to search but no luck...Any help would be greatly appreciated....
Old Mar 3, 2009 | 07:12 PM
Beemervet's Avatar
Beemervet
No. They adjust separately.
Old Mar 3, 2009 | 07:45 PM
boogiewithtuck
Thanks, that makes a bit more sense. Rather vauge in the manual, to me anyway.
Old Mar 3, 2009 | 08:20 PM
boogiewithtuck
Tried seperate adjustment - nothing. The dealer in Amarillo had the fairing off ~ 3 weeks ago to chase the cruise wiring (check engine light) and I think the mechanic dinked something up. The entire assembly moves; it was clear he had never worked on an FLTR. Looks like another AM ride w/ the high beams until I can get it in.
Old Mar 3, 2009 | 08:52 PM
Beemervet's Avatar
Beemervet
What I meant was that they do not need to be done simultaniously, but if you are not getting any movement something is wrong. There is a HD service bulletin that gives a measurement for the adjusters with the fairing off. It is a good starting point. I am not home so I can't give it to you.
WacoCentex
May 15, 2017 11:22 AM
congo_usmc
Oct 18, 2014 11:18 AM
eberg
Mar 11, 2013 05:10 AM
1sweetglide08
Mar 13, 2012 09:08 PM
HarleyNoob77
Oct 8, 2011 07:55 PM
