Loctite or Anti-sieze?
Old Mar 4, 2009 | 12:13 PM
Baddflhtcu's Avatar
Baddflhtcu
Default Loctite or Anti-sieze?
I'm swapping out stock zinc bolts to chrome bolts on primary, tranny, cam covers, tappet blocks, etc. I am running them all thru a thread die first. Since these are steel (chrome plated) going into aluminum what should I use?
Old Mar 4, 2009 | 12:15 PM
RODEO's Avatar
RODEO
First choice would be anti-seize but in liew of that, Lock-tite will suffice too as it also has anti-seize properties. (blue or green). Better then not using anything at all. Lightly coat the whole bolt though.
Old Mar 4, 2009 | 12:43 PM
EasternSP's Avatar
EasternSP
Good tip there Badd. I wouldn't have the patience to die cut the chrome off before installing.
Old Mar 4, 2009 | 12:48 PM
jpooch00's Avatar
jpooch00
Personally, I'd go with loctite.
Old Mar 4, 2009 | 02:31 PM
kromdom's Avatar
kromdom
another vote for Loctite here.
Old Mar 4, 2009 | 02:34 PM
nemick's Avatar
nemick
Anti-seize for me
Old Mar 4, 2009 | 03:06 PM
Peppa1's Avatar
Peppa1
I'd look in the service manual and see what HD recommends and go with that.
Old Mar 4, 2009 | 03:39 PM
honestbob's Avatar
honestbob
+3 for locktite, it has thread locking ability so the bolts don't vibrate out. Never seeze does not it just protects the threads , as the name says.
Old Mar 4, 2009 | 03:47 PM
lonewolf_darkeyes's Avatar
lonewolf_darkeyes
Default hard choice
that is a hard choice to make. loctite will keep the bolts from vibrating loose but I'm not sure if it will stop the corrosive action between the steel and alunimium. The anti-seize will stop corrosion but is a lubericant and may let the bolts loosen.
Old Mar 4, 2009 | 03:48 PM
jberg's Avatar
jberg
I once made the mistake of running chrome bolts without die cutting or lube of any kind. Wow, what a disaster. As long as you're die cutting the chrome off first I'd go with Loc-tite.
