Road glide front hit crash bar
Old Mar 7, 2009 | 11:34 AM
bagman1's Avatar
bagman1
Originally Posted by gaser
I have a 2007 r/g an the front fender has hit the crash bar at the center mounting point . I have changed the fork oil an that helped some but it still will hit if you hit a big pot hole ,,,,,,,,,need help. Ps. This bike has a 21 inch weld wheel ana after market front fender but it is the same highth as a stock fender
Is it the same depth as the stock one? I mean in the back, it may have a deeper profile than a stock one. Perhaps you may have not put enough oil in and thats why its bottoming. Cant think of any other reason it would do that unless you took the forks apart and left a dampner out or have an aftermarket crashbar that is interfering.
Old Mar 7, 2009 | 11:46 AM
Hal@Ricor's Avatar
Hal@Ricor
Default Front Fender Hits
Ricor sells a spacer that will prevent that from happening. Add the Intiminators at the same time and it will make it a new bike. This hit was on a brand new 09 bagger, and the spacer stopped it from happening. Believe this will work on your 07 as Harley went back to dampners in 06, but please verify what yours is. We are a sponsor for this forum so I believe I am OK posting the link.
http://store.ricorshocks.com/SearchResults.asp?Cat=37
Old Mar 7, 2009 | 12:06 PM
gaser's Avatar
gaser
Thank,,,,,,,,,,,,,,,, you,,,,,,,,,,,,,,,,, that looks like it will fix it
utnick3
Jan 30, 2013 07:31 AM
outlaw bagger
Jan 23, 2013 08:21 PM
gaser
Feb 27, 2009 08:46 AM
spark1707
Jan 21, 2008 05:37 PM
tree88
Nov 30, 2007 06:22 PM
