shakes
Old Apr 26, 2006 | 12:42 AM
baitball's Avatar
baitball
Stage II
Default shakes
hi, where can I find a stearing damper for my 2006 FLHRCI. I tried everything, Iam getting wobbles from 70+mph.
Old Apr 26, 2006 | 12:57 AM
classic cruiser's Avatar
classic cruiser
Default RE: shakes
I would take it back to the dealer and get it fixed. Sounds like something didn't get set up right.
Old Apr 26, 2006 | 01:01 AM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: shakes
Get the biked looked at QUICKLY!!!!!!!!!!!!
The fallaway for the touring bikes are VERY specific.... If your bike is beginning to wobble at about 70 MPH, it could be that your steering stem bearings are a bit loose...
More than likely, the PDI tech failed to lube them adequately....
Old Apr 26, 2006 | 01:18 AM
electricuter's Avatar
electricuter
Default RE: shakes
I did 150 km/h and its a smooth ride,Id say Bob is right on the money with your steering head.
Old Apr 26, 2006 | 04:34 AM
Kahuna's Avatar
Kahuna
Default RE: shakes
You also want to have your motor mount inspected as well! A friend of mine has an '06 ultra classic, and just had the motor mount replaced! Your vibration at 70mph was the same exact symtom my friend experienced.
ORIGINAL: Shovelhead Bob
Old Apr 26, 2006 | 10:44 AM
ricoman's Avatar
ricoman
Default RE: shakes
All comments correct- you do not need a damper on your touring bike.
You need to check all as suggested plus wheel balance, truing, and tire pressure. You need to do this before you ride again.
This is a vary unsafe condition and not normal.
Old Apr 26, 2006 | 07:30 PM
saidin43's Avatar
saidin43
Default RE: shakes
As far as the tire trueing, if you've hit any large potholes recently, or other objects, that can easily happen. I hit a pothole hard with my sportster before I traded it in, and ever since that i had a wobble when driving. But I traded it in 2 weeks later, and the dealer didn't notice It was going to acution anyway
Old Apr 26, 2006 | 08:46 PM
baitball's Avatar
baitball
Stage II
Default RE: shakes
WOW, thanks for all you guys help, I made a appoiment with the HD service center. Also going to get the 1000 mile service
Thanks, Tony
jake318
Mar 4, 2019 01:05 PM
Torpedo1
Aug 13, 2016 05:04 PM
Silvio
Aug 10, 2015 11:33 PM
aframe2
Aug 20, 2008 09:38 PM
Pyrodex76
Jul 10, 2008 02:56 AM
