HHI vs. Performance Machine
Old Sep 16, 2014 | 06:37 PM
mmats69's Avatar
mmats69
Originally Posted by Manish_Hawg
I used a vendor who sold both. According to him, the PM was a little more expensive and a little bit better. However he said I wouldn't notice the difference. I went with the HHI because they were both on back order and the HHI came in first and I didn't like the fact that PM has their initials on the caliper.
The bike stops fine and I feel no safety issues with stopping, but the 1 thing I didn't like is there is no play in the front brake lever. I use to pull my brake lever almost to the grip to stop and now I only have to pull the lever 1/8 of an inch.
If it makes sense, pulling the lever close to the grip your hand is similar to a closed fist, pulling the lever 1/8 of an inch your hand position is like a "C" I feel I had more control of the bike when I have to pull the lever farther. To fix this problem you have to change out the MC which I will do later.
Interesting. Off topic but I run a dual 6 piston hhi setup and find I have to pull further back to get the same bite as stock.
Old Sep 16, 2014 | 08:51 PM
drspencer's Avatar
drspencer
That's because you're using two calipers. If you used one caliper, your lever would have reduced travel.
Scales
Apr 2, 2014 08:34 AM
JC650
Jul 2, 2011 03:47 PM
rkgal
Aug 24, 2009 03:05 PM
PiedPiper
Jul 25, 2009 03:20 PM
jopr175
May 24, 2006 11:36 PM
