break Switch?
Old Mar 10, 2009 | 10:17 PM
RickyB's Avatar
RickyB
i have a service manual now and it does talk about a piece of cardboard. but again does this piece of cardboard act as a wedge that pushes up against the switch? this seems to be the case. i have it working for now with out anything but the lever up against the switch. thanks for those that are being helpfull...
Old Mar 10, 2009 | 10:23 PM
Kbore's Avatar
Kbore
Originally Posted by tencrore
No intent to "hi-jack" this thread, nor any intent to be sarcastic, but how does the brake switch break?
As pxs said, there is a switch "nub" that gets sheared off. Its actually a push button switch with a thick rubber boot over it. Squeeze the brake lever and you can hear it squeek- look in there with a flashlight where the brake lever disappears into the housing and you can barely see it when you squeeze the brake lever..
Old Mar 10, 2009 | 10:35 PM
fathertime's Avatar
fathertime
From: CHILLIWACK B.C CANADA: have a u.s shipping adress
Default switch
first thing i managed to bugger up on my roadking...i even heard the little plastic tip fly off
note to self: read first then wrench
Old Mar 11, 2009 | 05:22 PM
pxs130's Avatar
pxs130
Not exactly. This doesn't go against the switch. Pull your brake level and look at the gap that's created (looking from the front of your bike). It goes there. It essentially holds your brake level on, thereby relieving the contact with the brake switch.
soulpatch
May 27, 2019 01:14 AM
GroovusMagnus
2014-2024 Touring Models
May 16, 2015 08:03 AM
LKHA
Dec 29, 2014 09:25 PM
28gauge
Feb 18, 2009 03:04 PM
hbski
Dec 13, 2006 08:21 PM
