Automatic Primary Chain Tension Adjuster
Old Mar 12, 2009 | 08:28 AM
AtkRWC's Avatar
AtkRWC
I've been running mine now for about 22k and no issues. I had the primary cover off about 1500 miles ago and all looked in order. Chain looked great and the shoe did not have any excessive wear. Overall I am glad I switched.
Old Mar 12, 2009 | 09:05 AM
Theakerr's Avatar
Theakerr
No. Did the conversion on my 03 FLHTCi myself. Straightforward. Changed because trying to manually adjust the primary was a right pain even after I had made myself a measuring gauge. Note I really could tell when the chain was too slack and I have a friend who fried a bearing (when it was too tight
Old Mar 12, 2009 | 10:58 PM
dgretz's Avatar
dgretz
The auto tensioner was put on the 06 Dyna's along with the 6 speeds. Then was put on the 07's to present.
Put one on my 03 Tsport this winter. Easy job nto removing of chain. About 1 hr job from tear down to botton up.
If dealer has issue with them why is the MOCO still putting them on all big twin models from 07 onward?
Old Mar 12, 2009 | 11:38 PM
RBJones's Avatar
RBJones
It's an easy job and well worth it. You don't have to take off the chain, just the primary cover. I put mine on at about 24,000 miles, when I installed the easy pull clutch kit, which is another upgrade that's well worth it.
I have 61,000 on the bike now and I've never had to deal with the primary adjustment since installing the adjuster. Before, when the chain would get some slack, I could hear it clatter a little bit and feel some slack in the drive train. But I've never had the problem since. I did open the port and check it at about 32,000 and the tension seemed fine.
You can install it wrong and the instructions warn about setting it too tight. They explain how to re-**** the spring in case you do it wrong. If you install exactly according to the directions you really can't go wrong. In my experience, having a chain a little snug is much better than having a lot of slack. A slack chain will destroy your sprocket teeth in no time.
Old Mar 13, 2009 | 12:04 AM
Lonewolf176's Avatar
Lonewolf176
Check out the hydraulic tensioner from South Oregon Hot Bikes
Old Mar 13, 2009 | 09:48 AM
gilbos440rt's Avatar
gilbos440rt
I have the HB125 hydraulic tensioner and love it! I did install it a little looser than they said to, on a new chain I'd went with what they called for, but mine had reached the point of needing an adjustment so I set it up to the tight spot and it's been two years now and still in perfect adjustment Another plus it seemed to make finding neutral while the engine was running a lot easier, not that it was hard before just easier now.
Old Apr 11, 2009 | 10:01 PM
Kram Nala's Avatar
Kram Nala
Stage I
Now I'm curious... does an '08 FLHTC come with an auto primary chain tightener or not?
Old Apr 11, 2009 | 10:31 PM
dgretz's Avatar
dgretz
Was put on the 06 Dyna's and then all the Big Twin 07's. Installed one on my 03 T-Sport and no special tools or chain removal needed. Pretty straight forward install about 1 hours time.
Old Apr 30, 2009 | 03:40 PM
MCT's Avatar
MCT
Kram,
Not sure if your does or doesn't, but look at the primary cover. Do you have an inspection cover plate, or not? My '08 Dyna does not have the inspection cover and of course it has the new tensioner.
sgw1064
Jan 8, 2023 09:19 PM
Wisenheimer16
2014-2024 Touring Models
21
Jul 4, 2017 05:34 PM
imboden
Aug 23, 2014 08:21 PM
azharleyrider86401
Apr 8, 2011 05:43 PM
dyna081
Mar 3, 2010 08:46 AM
