Ran banjo to inside on mine and loosely wire tied cable to right riser. The right twist when making up banjo and cable forms perfect to bars. Did a little twist on lower cables also which bowed them out from fender when made up so the wouldn't scratch. Pics a little far away but you can see.
EZ - looks good. and looks like you have a little less cable than i've got. I think i'll leave it like it is and just make sure it wont rub inside the nacelle. (and to "match" the clutch cable running in front of the bars)
loseranacummins, do you have abs? If so, what parts did you use to put your apes on? I have an 08 RKC w/ABS. I have 14" chubby's but no idea how to put them on. H-D still, after a year, hasn't fixed the problem.
Sorry Lord, no ABS...and no clue as to whatcha gotta do for the install. I plan on doing a little write-up on my experience doing the install, so keep an eye out for that.
