Clutch Question??
Old Mar 28, 2009 | 03:17 PM
HDCopper's Avatar
HDCopper
I adjusted the clutch and every thing went well, I think? Is the clutch lever supposed to be against the grip when pulled in when it's in gear. The bike does not creep when at stop lights but feels tight at the grip. The clutch lever is about 1/8 to 3/16 away from the grip when I have it pulled in. Any ideas??
Rob
Old Mar 28, 2009 | 04:08 PM
gary_montague's Avatar
gary_montague
The 1/8" is not measured from the handle, it's the gap were the lever pivots.
Old Mar 28, 2009 | 04:55 PM
skratch's Avatar
skratch
i think a readjustment is in order. the clutch lever should be able to be pulled against the hand grip. like gary says, the 1/8 gap is measured at the pivot point. if you pull on the clutch cable, the little silver thing should be able to move from the handle 1/8 to 3/16.
Old Mar 28, 2009 | 06:06 PM
HDCopper's Avatar
HDCopper
skratch, readjust the cable adjuster only or the clutch pack too? The gap where the clutch pivots is about 3/16.
I turned in the adjuster on the clutch pack till I felt the slights resistance and then turned it back out 3/4 of a turn. My understanding is it call for 1/2 to a full turn out so I split the difference.
I think the cable adjuster is where I am making my mistake.
Y'all's input in very appreciated.
Rob
Old Mar 28, 2009 | 06:39 PM
1flhtk4me's Avatar
1flhtk4me
If you adjusted the clutch pack as you said,then readjust the cable to 1/16 to 1/8.
Would not hurt to lube the cable and lever pivot first.
Old Mar 28, 2009 | 08:00 PM
HDCopper's Avatar
HDCopper
Sounds like a plan. I have cable lube, but what do you guys use for lubing the pivot point? I have snap ring pliers so taking it out to clean and lube is no problem.
Rob
Torpedo1
Jan 29, 2017 08:07 PM
Kebo
Jun 22, 2013 07:29 PM
Tree Top Flyer
Sep 21, 2012 03:41 PM
hoethree
Jul 27, 2010 08:21 AM
bigkylewhite
Jul 25, 2006 01:32 PM
