Installed 30T Primary Gear.
Old Mar 22, 2009 | 11:22 AM
PTAG's Avatar
PTAG
Originally Posted by bagman1
Im wondering why you changed this sprocket and not just the final drive sprocket. I had an evo where I changed the comp sprocket and the bike wouldnt do over 50 on the freeway, but I could easily loose it in the first 4 gears it was so torquey. Now I have an 07 and did the 103 kit and lost first gear because it was so high I was surely going to burn out my clutch, and I could cruise between 45-100 in 4th gear. The final drive change was done and the only issue I had was speedo error of 4-7 mph.
Is this the same issue you had that lead you to make this change? If so I can post a list of the parts if anyone is interested. If Im talking about something off topic my apologies.
I made my change because the gearing was too tall for my taste in first gear. It not only fixed that but made it perform better in all gears. It now starts off in first close to the 09 I rode yesterday and performs like a 2006 in the other gears. That the best I can do to describe it. There is no ill effect except losing the 6th gear light. You say it was torquey but I don't see that all all. Maybe you are waiting to shift too long. That would give the feel you are describing.
I agree there is more than one way to change the gearing and I went with the 30T and new chain and it worked for me. If it hadn't I would have tried something different. This is the least invasive method of re-gearing.
Old Mar 22, 2009 | 11:25 AM
lp's Avatar
lp
Didn't in 09 they just add a larger Rear (belt) sprocket? To like a 70 tooth. Why wouldn't you 08 and below guys just do that? I'm sure someone sells a 70 tooth somewhere... Would loose the IDS though.
lp
Old Mar 22, 2009 | 11:28 AM
dawg's Avatar
dawg
Originally Posted by Feedsack
Why do you lose the compensator?
Because the EVO sprocket replaces the compensator sprocket.
Old Mar 22, 2009 | 11:31 AM
bagman1's Avatar
bagman1
No thats not it at all. By changing the comp gear to a smaller one the engine revs quicker so you go thru the power band hella fast (thats why the SE book only shows this gear for the track because you cut your cruising range back a couple of gears) Now I did that on a 5 speed, it may not be as crucial on a 6 spd, but I would think although it works you would be running at a much higher rpm range.
I think by going with the final drive gear change and using the Japan model belt, it doesnt change the driveability factor too radically.
Old Mar 22, 2009 | 11:37 AM
bagman1's Avatar
bagman1
lp
Because it is much easier to go with a -2 tooth final sprocket and go with the japanese model belt from HD. At least thats what the builders I talked to say, I think there was some issues on the thickness of the pullies where the bigger rear sprocket was for the wider belt and the bolt pattern may be somewhat different, not 100% on that though. And I did that on mine and it is sweet, and by doing this you may be able to keep the IDS. My $.02
Old Mar 22, 2009 | 11:38 AM
PTAG's Avatar
PTAG
That explains your problem. You wouldn't want to do this on a 5 speed. You need the 6th speed or it would act like you said.
nvsteve's Avatar
nvsteve
lp
On 07s and 08s you would have the cost of the pulley and a new belt. There is significantly more labor involved vs. changing either of the primary gears.
Old Mar 23, 2009 | 08:33 AM
cannedham1's Avatar
cannedham1
Default regearing 2007
I read about this same thing on another forum a couple years back. They called it a gear reduction I think. Ive got a 2007 rk and it sure could use a little regearing . Could someone please post part#'s and supplier source or website . How do you think it will work with 103" . Are you still able to hit high speeds on highway and cruise in 6th gear?
Old Mar 23, 2009 | 08:37 AM
dawg's Avatar
dawg
pn# EV-3084 as seen HERE
Old Mar 23, 2009 | 01:01 PM
up2nogood22's Avatar
up2nogood22
I'm ordering that bastage today. I can;t believe how high 1st is on my 08 RG.
I was doing some practice drag runs last week (4K dump the clutch), simply pulled the motor down and took off like an old lady.
