Update on Stablizer Fabrication
Old Mar 28, 2009 | 08:15 PM
roadking1893's Avatar
roadking1893
Default Update on Stablizer Fabrication
Been busy with work and kids having Birthday. I just now had the chance to fabricate the stabilizer. These photos is the prototype that will serve to fabricate a finish product.
Attached Thumbnails Update on Stablizer Fabrication-stabilizer.jpg   Update on Stablizer Fabrication-stabilizer1.jpg   Update on Stablizer Fabrication-stabilizer3.jpg   Update on Stablizer Fabrication-stabilizer4.jpg   Update on Stablizer Fabrication-stabilizer5.jpg
Old Mar 28, 2009 | 08:17 PM
roadking1893
Other Photos.
Attached Thumbnails Update on Stablizer Fabrication-stabilizer6.jpg   Update on Stablizer Fabrication-stabilizer7.jpg   Update on Stablizer Fabrication-stabilizer8.jpg   Update on Stablizer Fabrication-stablizer2.jpg
Old Mar 28, 2009 | 10:04 PM
AaronOregon's Avatar
AaronOregon
Former Sponsor
Looks good! They all basically do the same thing. Kinda like the new Progressive one out. Way to go.
Aaron
Old Mar 28, 2009 | 10:36 PM
Mike07FLHTC's Avatar
Mike07FLHTC
Nice job ,been thinking about making one myself.
Old Mar 28, 2009 | 10:41 PM
hogbag07's Avatar
hogbag07
Looking good
Old Mar 29, 2009 | 06:09 AM
rjmac53's Avatar
rjmac53
very nice...
Old Mar 29, 2009 | 12:02 PM
Gearhead1's Avatar
Gearhead1
Default Stabilizer mod
Just a suggestion I figured out after I made mine.
Slot the bottom hole that goes over the cap cover. That way you don't have to remove the exhaust to install, unless you want to. You can just back the bolt out, then slide the bracket in place, and retighten after the top bolt is installed.
I suggest you use 1/8 chromemoly steel to make the bracket out of since there isn't much room between the exhaust and bottom bolt head, unless you plan on spacing the exhaust out a little. The 1/8 chrome moly is as strong as 3/8 mild steel.
I got the chromemoly plate from McMaster Carr and had enough that I have made 5 brackets out of the 12*12 piece. Made mine and 4 others for friends.
Old Mar 30, 2009 | 10:30 AM
ROGERinSEMO's Avatar
ROGERinSEMO
How about making the slot for the bottom bolt at the 6:00 position rather than the 3:00 position. That way the natural movement of things would not tend to pull it out of place. Just an idea, might not work. looks like you are doing a GREAT job!!!!
KansasHellride
Mar 10, 2010 04:13 PM
cmiamt2009
Wheels/Tires
Feb 25, 2009 01:13 AM
downsmith
Mar 16, 2008 03:56 PM
UltraPassenger
Mar 12, 2008 06:43 AM
