Rear sShock pressure
Old May 1, 2006 | 08:33 AM
Timex's Avatar
Timex
Default Rear sShock pressure
Does tthe air assist in the rear shock suspension leak down? If so, how frequently should I expect to have to check it?
Old May 1, 2006 | 09:28 AM
spartns's Avatar
spartns
Default RE: Rear sShock pressure
I check mine about once a month and find that it's within a pound of what it was. Mostly the same as it was.
Old May 1, 2006 | 11:51 PM
Fatboy2's Avatar
Fatboy2
It shouldn't change. Are you checking the air preasure with Harley's pump/gauge? It has a least one check valve built into it. I am not one to buy Harley if I can find the manufacture that builds for them but....
I thought I was loosing preasure and even replaced the fittings that connect the plastic air lines only to find the gauge I was using was allowing air to escape each time I checked it. The gauge I was using was a quality gauge but did not have a check valve in it.
Old May 2, 2006 | 12:05 AM
soos's Avatar
soos
If you feel that your shocks do leak, they would be leaking all the time. If that is so I would pump about 20# into the shock and do a soapy water test on the fittings, both with and without any rider/passenger weight on the bike. If they leak you will know it with the soapy water.
Old May 2, 2006 | 12:09 AM
lil_gmac2's Avatar
lil_gmac2
I took all the pressure out of my rear shock so I don't need to check them ever.
Old May 2, 2006 | 12:17 AM
rapz's Avatar
rapz
I lost about 7lbs over two thousand miles, mostly riding two-up and in about three weeks.
Old May 2, 2006 | 12:44 AM
bay13's Avatar
bay13
I got the HD pump, it's small and has the check valve. I found that; 1) either all the air had leaked out from the time I bought it or 2) air was never added. I suspect #2, I put 10 PSI in and checked it a few weeks later and it was 10PSI.
VA_Larry
2014-2024 Touring Models
21
Feb 20, 2016 03:13 PM
rcreechssr
Apr 2, 2014 05:03 AM
clyles
Feb 18, 2014 09:09 PM
harlowr
Jun 27, 2011 04:37 PM
06BlackFLHXI
Apr 17, 2006 08:39 PM
