Truth in dyno
Old Feb 1, 2010 | 10:36 AM
  #131
hog-doc's Avatar
hog-doc
Thats a new one to me also. Iam looking at the SEST software on my laptop but dont have a bike to plug into at home using SEST. I dont see the tabs you guys are talking about. One says under tool box and the other says under the tuning fork, but I dont see it.
Old Feb 1, 2010 | 11:04 AM
  #132
Heatwave's Avatar
Heatwave
Member
I just went into the software and you don't need to be hooked up to the VCI to see the tabs or screens I referred to in the previous post.
Just to clarify. Once the software is open and you're past the disclaimer, you'll need to click on the "Tuning Fork" icon on the top menu bar. Once you click on this icon a new window will open. There will be a white screen in the middle of this new window with 2 tabs above it. One tab will say "Stored Calibration". This tab is the default that the software opens to and generally points to wherever you have stored your various tuning maps.
Next to the "Stored Calibration" tab is is a second tab labeled "VCI". Click on this tab and you'll see a new field with a button at the bottom labeled "Load From VCI". If you're not hooked up to the VCI, the button will be grayed out but you can still see it.
If you're computer is hooked up to the VCI AND the bike AND the main ignition switch is "ON" AND the hand control switch is in the "ON" position, then the "Load From VCI" button will become activated.
At this point you can click the button and whatever map is currently stored on the VCI will be downloaded to your computer. Once you've opened the file you can save it to your computer using the "Save As" function. Once its saved to your computer you can modify the map, rename it or do anything you want. My recommendation is to save 2 copies. One that's untouched as a backup and the other to be modified as needed.
Essentially any map on the bike that has been saved to the VCI can be pulled off the VCI by anyone with a copy of the 2010 SEST software so long as they have the bike AND the VCI that is mated to that bike.
Old Feb 1, 2010 | 01:21 PM
  #133
Jughugger's Avatar
Jughugger
Thumbs up
Originally Posted by Heatwave
On my 2010 SE Ultra with the 2010 SE SuperTuner, I was able to download the map that was on the bike and save it as a different file and make any and all changes to the file.
To download the file from the bike it's a simple matter of connecting the VCI to the bike. Have the software up and running. Turn the main ignition switch to "ON" and the right hand control switch to the "ON" position.
In the software, open the "tuning fork" tab. Then click the "VCI" tab. Then click "Load from VCI". The software will then download the current map that's on the VCI to your computer.
If this was a map created by a tuner or from any other source, you will now have the map downloaded to your computer. Once its been downloaded, you can "Save as" the map and store it as a duplicate to be modified however you wish or just to keep as a backup.
Unlike the SERT, the 2010 SEST absolutely allows you to download the existing map that's running on the bike so long as its still on the mated VCI. I've personally done it this week after my bike was tuned by the dealer.
Thanks Heatwave! I am also running the latest 2010 software on my 2010 Ultra. Your explanation is exactly how I did it, just didn't explain it as well.
Old Feb 1, 2010 | 01:32 PM
  #134
hog-doc's Avatar
hog-doc
Thanks for the info, never even noticed that tab before!
Old Feb 1, 2010 | 02:08 PM
  #135
harleytuner's Avatar
harleytuner
Me neither. Thanks. Great stuff, gotta love the forums.
Old Feb 1, 2010 | 09:43 PM
  #136
EasyriderFI's Avatar
EasyriderFI
Default Eye opener
Originally Posted by harleytuner
Being a dyno tuner it troubles me to see some of your printouts posted on here. Their are different units of measure to measure horse power and torque. The main 2 I see here is STD and SAE. STD is a unit that is used over in Europe and is about 2 - 3% higher than SAE (which is how we measure H.P. in the States). So if your printout says STD smoothing anywhere on it, and you live in the states, than your tuner is giving you false info. There is only 2 reasons I can think of that tuners would do this, 1 is that they just don't know any better and 2 is that they are trying to have higher #'s to make them look better. The other thing that bugs me is some of the A/F lines I see, or lack of. Bottom line is, if they can't read your A/F then they CANNOT perform a full tune, if they don't have a 250 dyno, they CANNOT perform a full tune. If they give you a "full tune" and don't show you the A/F calibration then they are hiding something. If you do have the A/F on your printout, it should be relatively a straight line, at around 13.2 : 1. Anything below that line is rich and anything above it is lean. That's NOT where your bike is running, (when you get it back) that is just where it is calibrated. Your Dyno lines should be smooth, when they get real wavy, usually at higher RPM's then your timing is probably off.
I have seen many posters on here that attempt to tune there own bikes off of their dyno printout, It can't be done properly. Your printout is only showing 1 cylinder at full throttle, it might me totally different at other throttle positions, so if your printout shows your bike is running rich at 2500 RPM's and you decide to lean it out a little across the board, guess what? Your bike might of already been lean at cruising and you just leaned it out more.
What a surprise this was and I was a little afraid of the money that I have spent to get my bike to a certain goal of numbers since my first dyno from my HD dealer once my stage 1 was installed but once I looked at the dyno, it said STD also. My numbers my not be cut and dry true but all my graphs are on the same STD code so the increase is true.
Thanks for the info, I need to spread it now.
Old Feb 1, 2010 | 09:55 PM
  #137
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Excellent information
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Jul 27, 2010 | 06:18 AM
  #138
RangeRat's Avatar
RangeRat
Tagged for future reference
Old Jul 27, 2010 | 07:00 AM
  #139
scj's Avatar
scj
You can try 13.2 but on some of the higher compression builds you may see detonation at higher rpms if it is that lean. Removing timing when it needs more fuel makes for an unhappy motorcycle. Your graph lines will not be smooth.
Finally, someone that really knows what he is talking about.
My 13.2 to 1 dyno tune had my engine knocking like a wood pecker.
Ran great while they had the knock feature disabled on the dyno then they turned if on before they gave it back to me and it ran like crap. I wonder how much engine damage was done during the 60 miles of dyno tuning that day???
Both tuners that have touched my bike also tuned my engine with the wrong timing tables. You would think they know that a 260 HD cam has a .609 lift and use a base map that starts with timing tables available for that cam as well as what size TB & the cubic inch are you using!
I'd bet there are not 10 tuners across the states that know how to really tune a bike that has more than an a/c and small cams installed.
One tuner focuses on air to fuel and another on max hp & tq but none I have seen ask what compression are you running, do you ride two up, what kind of fuel do you use, did you change gearing, do you ride the freeway a lot, etc.
End of rant!
Old Jul 28, 2010 | 03:19 AM
  #140
EasyriderFI
Default I learned a lot from this post.
GREAT INFO I came out of the dark when I read this a while ago,
user 46092
The Dyno Room
Sep 27, 2016 09:28 AM
HKMark23
General Topics/Tech Tips
Jan 3, 2016 05:20 PM
prondas
Feb 3, 2013 09:03 AM
hog95023
May 20, 2009 05:56 AM
GMarx
Jun 10, 2007 02:58 AM
